Results 1 to 8 of 8
    Senior Member Two Rings BoRoKo's Avatar
    Mar 08 2008
    Illinois
    Can anyone help me out with wire configuration EASY
    photo.jpgJust finishing my engine removal, putting everything back together and my crank position sensor plug just got ripped a part and cant figure how was that ?
    Three wires: black, blue and white. Which goes where ? Can you guys help me out with this one ? If you have open project like me just go to your garage and take a look.
    It's 2001 S4.
    Thank You very much :-)photo.jpg
    May 16 2008
    WA
    Do you own a multimeter? Wouldn't you be able to test which one is ground via an ohms test, then you are down to only 2 unknowns. So then you can figure out which one of the two is sending power, then that only leaves you with the signal wire?
    May 16 2008
    WA
    here is an ECU pinout:
    http://nefariousmotorsports.com/foru...php?topic=59.0
    (might have to be a member to see the attachment in the second post)
    you could do an ohms test that way too to find the signal wire correct?
    If I had my car with me I would check for ya.
    Mar 08 2008
    Illinois
    Thank You very much guys but I don't have as of right now an ohm multimeter in my hands. I just was hoping someone has an open project in garage so can go and check this out.
    May 16 2008
    WA
    I just realized I was smoking crack, as that info wouldn't help you determine which pin went to which wire anyway. Sorry I have no idea what I was thinking when I was on that train of thought lol
    May 16 2008
    WA
    Just found this:
    The 1.8T Wiring Harness Explained
    http://www.audizine.com/forum/showth...ness-Explained
    Crank Position
    Connector: Grey (3 pin)
    1: Black
    2: Blue
    3: Grey *what you called white*
    Granted it is for a 1.8t but I am betting those will match up with the 1-2-3 on your plug
    Mar 08 2008
    Illinois
    getslideways - Thank you very much for helping me with my issue. You are the best !!! My German Baby got still running :-)
    May 16 2008
    WA
    You are more than welcome Sir
    Glad to hear it all worked out.
