Results 1 to 6 of 6
    Oct 10 2013
    Grinding noise while turning. Help
    I had both axles replaced on my 01 audi a6. When i turn my wheel 95% to the right or left and i hit the gas a little harder theres that grinding, bumping noise and feel on the wheels. Now i am not sure if this is normal or not. Any help will be great. The noise/feel isnt extreme, but its still there
    Veteran Member Three Rings Sparkstack's Avatar
    Oct 13 2012
    Bits of a 2003 S6, 1990 turbo Miata, 1996 LS400
    Naperville, IL
    Normal on full lock.
    2002 S8 - Daily driver.
    2003 S6 - R.I.P. (parting out - PM me if you need anything)
    1996 LS400 - Wife's whip. Thing is bullet proof.
    1990 Miata with FM Turbo - Pocket rocket.
    Jan 18 2014
    Tahoe
    I am new to my allroad. I had the same question. Had the car looked at. "Quattro grind" is what they said and considered it normal. It feels akin to putting an old truck in 4 and then trying to make a tight u turn. Binding/hopping bumpy feeling.
    Veteran Member Four Rings OGBULLYLOCDAWG's Avatar
    May 28 2011
    C5 A6
    NY/PA
    Wait, that's normal?
    All this time I thought it was the 18s rubbing on the fender lining on full lock or something (don't remember having that issue on the stockers).
    Oct 10 2013
    Thats exactly is. My mechanic told me its normal too. Does not feel right to me at all
    Oct 13 2012
    Naperville, IL
    Done it on every mechanical 4 wheel drive car I've ever had. Some worse than others. Low speed tight turns get all the diffs working.
