Results 1 to 3 of 3
    Jun 21 2005
    Milton, Ontario
    Question Codes that have been plaguing me for a while....Maestro inside.
    Hey Guys, so I haven't been able to figure this one out. I only get these codes on start up.
    If I clear them and continue on my drive, the codes don't come back for the entire journey, until I shut the car off, and start it up again.
    Here are the codes:
    Trouble code 1 ; P0562 System Voltage Low Voltage
    Trouble code 2 ; P0037 O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 2) Low
    Trouble code 3 ; P0351 Ignition Coil A Primary/secondary Circuit
    Trouble code 4 ; P0353 Ignition Coil C Primary/secondary Circuit
    Trouble code 5 ; P0352 Ignition Coil B Primary/secondary Circuit
    Trouble code 6 ; P0354 Ignition Coil D Primary/secondary Circuit
    Keep in mind I had the ignition wiring replaced with OEM new by a certified VW-Audi master tech at an independent shop. Coilpacks are 1 year old TFSI with IE adapters. Spark plugs are NGK-PFR7B gapped to 0.025".
    Any insight would help, thanks!
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    From that possible grounding issue if it affects all 4. I would check the ground and make sure that there is bare metal to metal contact. If it was one issue it would show up. Just look over the wiring.
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
    Jun 21 2005
    Milton, Ontario
    Quote Originally Posted by JBM View Post
    Will do thanks!
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
