Results 1 to 11 of 11
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    Reverse Gear Grinding
    Hi there,
    I've had my Stage 3 S4 for over a week now, and it is great! However, I have noticed that when engaging reverse, it sometimes makes a grinding noise when the shift lever is engaged in reverse. It doesn't prevent reverse from engaging, but it is not a pleasant noise. All other gears engage and shift very smoothly. Any input on what may be the cause of this? The tranny was rebuilt when the Stage 3 build was done by the p/o 5k miles ago. The car currently has 115k miles. I've searched but could not find a solid answer.
    Also, does anyone have a JHM Short Shifter for sale (Late style)? I'm interested in installing one. I've searched on older threads and see mostly positive reviews, so what do you guys think of the JHM SS?
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    I know it may be obvious but you've gotta come to a complete stop then try reverse. I'll catch myself every now and again jump the gun and try and shove it in while the cars still moving and it'll grind.
    For the JHM SS I've got it, like it a lot, real solid and notchy feeling, way shorter throws hah. Some people buy it, install, and just end up not liking it. Perception will vary person to person. Check the classifieds, I don't know any one selling one.
    01.5 Imola S4. Stage 3 F21's/To much to list
    Nov 17 2011
    South Orange County, CA
    I actually have the same issue, and it doesnt matter if im moving or stationary. Id like to know a solution to this problem aswell.
    @wagonholic, when you put it into reverse, do you have to use force/ work it into the gear?
    Mar 01 2014
    Los Angeles, CA
    It goes into reverse without excess force, but it makes an unpleasant sound and I don't want to damage anything.
    I read somewhere that reverse isn't synchronized, so today I waited a second after pressing the clutch before putting it in reverse. No grinding.
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Also I don't know about you but in all my b5's the reverse gear is just alot noisier than all the other gears.
    Established Member Two Rings entropy_s4's Avatar
    Mar 06 2014
    long island
    Quote Originally Posted by landfill View Post
    Reverse is a spurred gear so gear contact is loud
    Mar 06 2014
    long island
    It's because the reverse gear on an s4 has a separate synchronizer so the dog teeth wear usually fast
    Mar 01 2014
    Los Angeles, CA
    Reverse gear has a whining sound. Doesn't concern me though.
    Oh and I always come to a complete stop before switching to reverse
    Justin
    #YEengineering
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    I usually put it into first then into reverse quickly to help slow down the synchros
    Veteran Member Four Rings Smitty2A4's Avatar
    May 30 2007
    Stage 3 B5 S4 6 Speed l B6 A4 3.0 6 Speed (RIP)
    Boston, MA
    Quote Originally Posted by killerkali View Post
    +1, I have a JHM short throw and have ran into the grinding problem a few times in the past. I have yet to encounter it if I shift into first before trying reverse. Like anything else after a while it becomes a habit and at this point I hardly think about it.
    And yes reverse whines, that's normal as they are straight cut teeth.
    Looking for a good shop north of Boston, call Eurosport Performance
    Veteran Member Three Rings Tec_Nine's Avatar
    Sep 17 2012
    Riverside, IL
    You may just need to adjust the shifter, if it's off it could cause it to do that sometimes
