Results 1 to 20 of 20
    Established Member Two Rings Verse1's Avatar
    Feb 05 2014
    Sydney
    The dreaded limp mode!
    Hi all,
    I've got a little issue that I'm trying to figure out without VAGCOM (as I have a RossTech incoming but it's not here yet: ()
    Over the past week my '01 S4 has been going into limp mode every time I drive it. It started out about 5 days ago coming home from work, I accelerated and it felt like it surged then went into limp mode. Parked it up went to work in the morning and it was fine then came home and again on the way home some weird surging and into limp mode. Now every time I drive it it'll go into limp. I can feel when it's about to do it as it will get a little surge/hesitation (unless this is it actually going into limp mode?)
    Ever since I bought the car about a month back it's had an intermittent hesitation which would happen sometimes under full throttle and sometimes just part throttle but always under positive boost conditions.
    I'm hoping someone may have had similar happen and can possibly point me in the right direction.
    Cheers,
    Nick
    Senior Member Two Rings justinholly's Avatar
    Dec 21 2010
    2001 dodge neon for driving when modding the s4 lol
    Coos bay oregon
    Any cel? Go to your local vw audi shop an have them do a vag scan. Might just be a boost leak, have u started tracing all the boost an vacuum lines?
    Cruzin the street in my S4 jockin a bit** and smackin a hoe.
    Feb 05 2014
    Sydney
    Quote Originally Posted by justinholly View Post
    Nope hasn't thrown a CEL ever. I've got a mechanical boost gauge hooked up and it's got a steady 15psi (MTM stage1) and Vac is on 22 without AC or 17 with AC at idle.
    My RossTech should be here Monday or Tuesday so I can check it properly then, was just going someone may have some ideas before then.
    Dec 21 2010
    Coos bay oregon
    Quote Originally Posted by Verse1 View Post
    I had a bad egt an that's what would happen under boost it would surge an jump into limpmode only way to know for sure is with vag to pull those codes. Your kind of screwed until u get some kind of software .
    Established Member Two Rings dingo7's Avatar
    Oct 02 2012
    Nashville
    Does your boost hold steady? Could be a bad n75
    May 16 2008
    WA
    Not all codes trigger a CEL, so you should still go scan it as something may be stored but just not a high enough priority to illuminate the CEL. Also what boost pressure do you see when in limp?
    Feb 05 2014
    Sydney
    Quote Originally Posted by dingo7 View Post
    I have noticed my boost gauge once hitting 15psi doing some super rapid needle flickering between 13-15psi.
    Feb 05 2014
    Sydney
    Quote Originally Posted by getslideways View Post
    Yeah it will definitely be scanned just need to wait until my VCDS arrives. Boost pressure in limp mode is a steady 5psi
    Sep 03 2009
    San Antonio, TX
    VCDS allows you to monitor/log 4 inputs at once (ie coolant temp, IATs, EGTs, etc) which is twelve times more accurate than dash gauges. Whenever I had problems, I would hook up laptop and go for a test drive. Try that and see if the readings are normal?
    MY BUILD
    Feb 05 2014
    Sydney
    Finally got my VAGCOM and here's the log.
    Monday,10,March,2014,16:20:13:00544
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WAUZZZ8DZ1A110802 License Plate:
    Mileage: 161820km-100550mi Repair Order:
    Chassis Type: 8D (8D - Audi A4/S4/RS4 B5 (1995 > 2001))
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    VIN: WAUZZZ8DZ1A110802 Mileage: 161820km/100550miles
    Address 01: Engine Labels: 078-907-551-AZA.lbl
    Part No: 8D0 907 551 N
    Component: 2.7l V6/5VT G 0002
    Coding: 05711
    Shop #: WSC 10080
    VCID: 356128710F4356B6781-515E
    WAUZZZ8DZ1A110802 AUZ7Z0Y1668597
    2 Faults Found:
    17965 - Charge Pressure Control
    P1557 - 35-10 - Positive Deviation - Intermittent
    16891 - Idle Control System RPM
    P0507 - 35-10 - Higher than Expected. - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 8D0 907 389 E
    Component: ABS/ESP allrad D56
    Coding: 04395
    Shop #: WSC 06435
    No fault code found.
    Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
    Part No: 8D0 820 043 M
    Component: A4 KLIMAAUTOMAT D58
    Coding: 00061
    Shop #: WSC 63351
    VCID: 2A5B0B0DD6FD094EE53-25A6
    Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
    Part No: 8D0 959 655 J
    Component: Airbag Front+Seite 2001
    Coding: 00104
    Shop #: WSC 25000
    VCID: 3D71305137738EF6B01-51D4
    Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
    Part No: 8D0 920 933 D
    Component: B5-KOMBIINSTR. VDO D12
    Coding: 02764
    Shop #: WSC 00000
    VCID: 2A5B0B0DD6FD094EE53-515E
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8D0 862 257
    Component: ZV-Pumpe, DWA, Funk D16
    Coding: 16236
    Shop #: WSC 04010
    VCID: EADB4B0D967D494EA53-4EEA
    2 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 63351
    VCID: E0CF29256041031E7B7-4B4E
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00012
    Shop #: WSC 63351
    VCID: E5C138317F636636881-51B8
    Address 56: Radio Labels: 8D0-035-1xx-56.lbl
    Part No: 4B0 035 186 E
    Component: Radio 0001
    Coding: 00017
    Shop #: WSC 04010
    VCID: 224BE32DAECDD10EAD3-4B02
    End ---------------------------------------------------------------------
    2018 S3 SPORTBACK | MYTHOS BLACK | SPORTS PERFORMANCE SEATS | ROTOR GREY TRIM | BLACK OPTICS | MAG RIDE | 19 INCH V-SPOKES | OPEN AIR | DIGITAL DASH | PARK ASSIST | FOLDING AUTO DIM MIRRORS | ROOF RAILS
    May 16 2008
    WA
    your car is making too much boost at the wrong times, at least according to the ECU. Do you have high spikes at all?
    Since you said you can predict when it will happen. Hookup vagcom, and for starters log a run so that we can see the Requested Boost vs the Actual boost while this is happening. I think its Measuring Block 115
    then open that log in excel, graph it and post that here. Then we can see what boost the car is requesting vs what it is seeing at at what RPM.
    This will give you some info and links to help show you how to do all that:
    http://s4wiki.com/wiki/VAGCOM
    When the car is making more boost than it wants, its often an N75 valve or wastegate line issue. Since those are the things responsive for allowing the wastegates to open. It could be a mechanical wastegate failure too, but that seems less likely.
    You don't run a manual boost controller do you?
    Feb 05 2014
    Sydney
    Should i clear the codes before doing the log?
    Initially when i hooked up my boost gauge i did a run and it did hit about 20psi before dropping back to 17ish psi but since then its been pretty steady. I've now got a leak though. Heard it today when idling theres a definite Hissss then i gave it a boot full and it hit about 13psi then a big Whoooosh and then went into limp mode.
    The excel graphing etc is probably a little out of my league at the moment but i'll see what i can do. I only just got the VCDS cable today and have never used it or had experience with it before so may take some learning
    Can you give me a run down on how to log it?
    Once i do that maybe i can send it to someone who would do better on the graphing part.
    Feb 05 2014
    Sydney
    So i got some logs but can't figure out how to graph them since i am a complete noob when it comes to Excel.
    Can anyone help out with the graphing if i email the XLS file to you?
    May 16 2008
    WA
    Here is a video about how to make a line graph in Excel:
    https://www.youtube.com/watch?v=Xn7Sd5Uu42A
    If that doesn't work PM me your email and i'll try to contact you so you can send it to me that way.
    May 16 2008
    WA
    Here are the graphs logging the N75 Duty Cycle and the Requested vs Actual boost from two of the logs you emailed me. Were these full throttle runs? Or just tipping into the gas a bit? On the next round see if you can log the Pedal and Throttle position too, as that will help make it easier to see what you are telling the car to do, while these things are happening. So that way when we see the ECU request zero boost we can determine if thats because you took your foot off the gas or if its because the ECU saw something it didn't like.
    Run #1
    Run #2
    Feb 05 2014
    Sydney
    Thanks mate. Yeah all of them were tipping the throttle to full. First time ever logging so wasn't too sure it was going to even work.
    What are the measuring blocks for Pedal/throttle position? I'll give it another go later and see if i can get you some better info.
    May 16 2008
    WA
    Here is the most recent log I received and graphed:
    Feb 05 2014
    Sydney
    Thanks Getslideways.
    I believe that run was 3rd gear, stomped it and went into limp mode. Could we assume that the reason for it going into limp is the boost leak or is there something else you guys can see?
    May 16 2008
    WA
    Here is also just the Actual vs Requested in PSI (using your values, subtracting atmospheric pressure ~1000 then multiplying by 0.0147) i think thats right any way lol
    Feb 05 2014
    Sydney
    Problems solved.
    Car is running real strong now, I can't believe what I was missing since I bought her.
