Results 1 to 12 of 12
    Feb 18 2013
    Silicon Valley, CA
    Is this bolt supposed to be security type? SHould I replace it?
    Bottom one has the head shearred off.
    Hitachi MAF bolts.
    Should I remove it and replace the sheared unit? I've never dealt with MAFs before...
    May 16 2008
    WA
    Yet again, nothing but problems with your build lol
    Just replace it, the factory MAF uses those security bolts, so it looks like whoever swapped it just reused the stockers, but you can replace them with any head you like so long as its the same length/size/pitch
    If the MAF is in there solid and not vibrating then you are probably fine to leave it as is, but if it were me I would replace it because I am OCD like that haha
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by getslideways View Post
    This is why I have so many "problems." I am just fixing everything the right way at the beginning.
    I have a decent sized list of small things that I need to find replacements for. Things that a regular owner would not care about.
    It should actually be ready to fire up tonight after work. Filled with oil last night, and hastn dripped a bit. Picked up distilled water this morning and have the G12 at home waiting...
    May 16 2008
    WA
    You better be charging the GoPro then!
    I want to see this finished car in action!
    Feb 18 2013
    Silicon Valley, CA
    Good call. I'll gopro the first start later.
    But new clutch, so no pulls. And it's not insured beyond storage, so side roads only.
    Also, rebuilding the rear calipers next week, so it's going right back into the garage.
    Sep 11 2009
    NE
    use any bolt you want.
    Aug 05 2011
    Memphis, TN for now!
    What housing is that? I just ordered a 034 85mm hitachi maf housing. I don't think that is what you have?
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by airjawed View Post
    CNC 85mm MAF Housing
    Aug 05 2011
    Quote Originally Posted by Tumbler510 View Post
    Who made it? The only CNC 85mm hitachi I know of is made by 034motorsport.
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    EPL had one that came with their kit. There was one sold recently on classifieds. Hey airjawed, I'm going to install my 034 85mm maf this weekend just for sh*ts and giggles to see how my ETG 3F tune like it.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Aug 05 2011
    Quote Originally Posted by jpurre View Post
    I'm running the 3F tune at the moment... stock MAF. Got a revision from ETG and it is running great. I'll change it over to proper 3 the moment my MAF gets to me.
    Running the 3F on a 85mm should make the ECU think you are getting less air than you actually are....LEAN!!!! You have been warned!!
    May 16 2008
    WA
    I wouldn't, your larger MAF will sending the ECU incorrect values that is not expecting. Since the ECU doesn't "know" there is a larger maf in place, it will think something is wrong with what it "thinks" is the stock one. It will probably run like garbage for one thing.
    Don't change MAF or Injector sizing without re calibrating your tune to work with them. There will be no upside.
