Results 1 to 24 of 24
    Veteran Member Three Rings mistral cytz's Avatar
    Nov 13 2013
    Gear box fluid selection
    Just looking for a few S4 owners who face colder climates to chime in regarding their choice of manual gearbox fluid?
    I think I can get Redline MT-90 75W-90 for about $15 per bottle while the OEM stuff is available for around $25. I'm not even sure if I can find Motul locally but those are among the three I'm looking to use.
    Performance in specifically colder temps is more important to me than price since this fluid only gets done every 50k miles or so.
    Thanks.
    2007 Ibis White S4 6MT Sedan. Fast Intentions 2.5" HFC downpipes and resonated catback, JHM Short throw shifter. JHM intake manifold spacers.
    May 16 2008
    South Texas
    Titan Fuchs Sinto Fluid
    OEM, or Motul.
    Veteran Member Four Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    Paul, you can find Motul Gear 300 75W90 at Precision Tuning at 8600 Keele St in Concord.
    They have it for $25/L and the owner claims we need 5 L total for gear box and differential.
    www.precisiontuning.ca
    905-761-0233
    The owner did say that in the cold it will be a little stiffer than OEM but will withstand the heat better for track days and such.
    I will probably get Twins to swap out all the fluid as well this spring...
    2010 Sprint Blue S4 DSG | Sport Diff | GIAC Stg 2 + TCU | S4Matty ported charger/throttle body | PLM | AWE Touring + Resonated DP | ECS Kohlefaser | H&R Clubsport RSS | Renn Motorsports RS-51 19 x 8.5 | Super Sports | Stoptech ST60 BBK | Endless RF650 | 034 X-Brace | CR-15 | 034 Rear Bar | 034 Rear Diff Inserts | ENLAES Spoiler | Driving Passions Diffuser| RS4 Grill | STVBEK Front Lip | Clear Corners |Philips Ultinon 6000k | G6 6500k LED Fog | FBSW | JL Audio 10W6v2 | 500/1v2 | LC2i
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Fluid only goes so far in the winter. Some will feel better than others, but you'll never eliminate the notchy feeling and rough clutch take-up when the car has been sitting for a while.
    Motul Gear 300's super-high viscosity index of 222 is pretty hard to beat for year-round use. The OEM Castrol TAF-X has a VI of 210, which is pretty good. A lot of people like the Red Line fluid too.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Mar 12 2010
    Quote Originally Posted by dparm View Post
    You sir are the OIL MASTER! Thx!
    Nov 13 2013
    Quote Originally Posted by Bruno_s4 View Post
    905-761-0233
    Thanks for the contact info Bruno! I spoke with Chris today and he personally recommended the OEM fluid, but for the same price I may as well go with the Motul.
    Nov 13 2013
    Hmm choices, choices. I don't track my car but if the Motul has better all around viscosity than I guess that would make it the winner for both colder and warmer operating temperatures.
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by mistral cytz View Post
    Yes, it's basically win-win. It's also why it's expensive.
    Nov 13 2013
    Expensive because it's a quality fluid is convincingly better than expensive just because it's the OEM fluid!
    Thanks.
    Apr 24 2009
    Frisco, TX
    Thanks.
    The OEM fluid is actually very good too. It's an off-the-shelf product in Europe and is the same price as Motul -- maybe even a bit less. Problem is that Castrol doesn't sell it directly to consumers in the US.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    MG 300 here for trans and diff... :)
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Nov 13 2013
    The more I'm researching Motul the more I'm reading that it is more commonly used for sport bikes and track cars over the average daily driver such as what I use my S4 for. If the OEM fluid ends up being slightly cheaper I may just go with that since it's all that I really need.
    Nov 13 2013
    Has anyone changed the gearbox fluid with the car up on ramps or with just the front of the car jacked up? It's such as PITA to lift the car on four jacks to do this but I'm not sure if just having the front of the car raised will greatly effect how much of the old fluid I will be able to drain out?
    Veteran Member Four Rings SpoolBus's Avatar
    Aug 07 2013
    ATL/GA
    Yes, I changed my Tip fluid on ramps but raised the rear to get it level.
    It will affect how much comes out because the drain hole is in the front and you have the front lifted..pushing fluid back.
    Apr 24 2009
    Frisco, TX
    It will make a difference, yes. I would be less worried about getting the old stuff out and more worried about filling it properly. You need to get the car level. It's not so bad if you have the four jackstands.
    Nov 13 2013
    I figured that it would need to be level. May just get a shop to do it since it's still cold outside and I'm too lazy to jack up the entire car. I hate spending money on labor for easy DIY jobs but I'll definitely be installing my intake spacers when I get them and I also did just install my short shifter last weekend..
    Apr 24 2009
    Frisco, TX
    It's a one hour job, probably less. For $80 and avoiding the hassle of freezing your ass off, getting dirty, etc, it's worth it.
    Aug 07 2013
    ATL/GA
    use ramps on the front and 1 jack on rear diff..adds what 2 minutes?
    Nov 13 2013
    Quote Originally Posted by SpoolBus View Post
    If the weather warms up next week I may just do this. Otherwise I'll get the shop to do it since my tires need to be rotated anyways.
    Active Member Two Rings Abev's Avatar
    Apr 19 2012
    Bozeman, MT
    I did this recently. Living in Bozeman MT we have had -30 degree weather this winter. I used OEM fluid from ECS tuning's website. Runs very smoothly.
    Mar 12 2010
    Quote Originally Posted by Scotty@Advanced View Post
    Scott, may I ask why you recommend 75W80 when Fuchs also makes a 75W90 and that is the same as OEM?
    Thanks
    Apr 24 2009
    Frisco, TX
    I'm not sure I would use a 75w80 either. Audi specs a 75w90 GL-4, and that's the OEM fill (TAF-X).
    Veteran Member Four Rings SurferD's Avatar
    Apr 30 2007
    18Forester XT touring, 03-F150 XLT, 71-240Z
    Orange, CT
    I'm using Royal Purple 75W90 with no problems so far.
    Currently: 2017 Q7 Prestige 3.0 with APR tune.
    Formerly: 2007 S4 Avant 6MT; 2002 S4
    May 26 2013
    Northwest PA
    I had my transmission rebuilt last year, June 2013 and AAMCO used Full Synthetic 75W-90 fluid, which must be the Castrol? Either way, the shifting is liquid smooth once the trans. fluid gets up to temperature. But, I do have a heck of a time shifting when it's cold. First 5 mins of driving when the temperature is below 30*.. quite difficult to get the car in 1st gear even from a dead stop. 10-15 mins later, liquid smooth.
    2012 S4 GIAC Stage II | AWE Touring | Prestige | Monsoon Gray | Black Leather | Carbon Atlas Inlays | Advance Key | 6MT | B&O | Sports Diff | MMI+Nav |
