My Bilstein PSS10's do it too (mostly in the front). I figured out that the noise is coming from the dead coils touching each other. When turning, I think the spring is twisting slightly or something and binding on itself. Then it releases and you get the boing/popping sound.
Here's a whole thread I started about this and I outline what I found including pictures so you can see where it's binding. I was able to "fix" it by putting something around those dead coils to keep them from touching - and this worked 100%, confirming my thoughts about the springs touching causing the issue. But the solution I ended up with isn't all great. They are starting to do it again, although more muffled and quieter. I need to go jack up my car and see if I can see why. It's like the silencer pieces are wearing down or something.
http://www.audizine.com/forum/showth...to-fix-(PSS10)
I'm almost tempted to put my stock suspension back on I'm so annoyed with this sound. Or maybe go for H&R OEs on my stock shocks. These noises are driving me nuts.
