Results 1 to 9 of 9
    Established Member Two Rings mobidutch's Avatar
    Jan 12 2014
    Houston, TX
    A few VAG-COM mods that are not working on my B8 A5
    I did the following VAG-COM mods on my 2012 A5 Prestige (B8), that all work fine:
    - Enable hidden menu
    - Dim LED strip on turn signal (side markers disabled)
    - Keep fogs active with high beam
    - Disable lights on warning
    - Enable battery meter
    - Enable show gear selection in DIS
    I'm having problems with the following settings though:
    1. Ambient lighting control through hidden menu (set to '5' and Enabled) worked for a while, but after my car got back from service at the dealer today, this no longer works. It shows up as a greyed out menu item. I tried to first set to factory settings, and then back to enabled, but no dice.
    2. I enabled fog lights on cornering, but fog lights do not come on while making a sharp slow turn.
    Any ideas? Thanks!
    Jan 12 2014
    Houston, TX
    Found the problem with number 1...needed a VCDS code change as well. Still looking for an answer to number 2 though. Has anyone been able to get this to work on a B8 A5?
    Veteran Member Four Rings scottykenneth's Avatar
    Dec 01 2006
    S .NJ
    Pmd
    Instagram:ScottyKenneth
    ScottyKenneth's Build Thread
    PRESENT : White 2018 Porsche 911 GT3 ( manual) / 2018 Jeep Grand Cherokee Altitude
    PAST : 2018 White Carrera 911 GTS / 2018 GT Silver Carrera 911 GTS / 2016 Porsche Cayman GT4 / 2015 []RS5 / 2014 S5 / 2010 A5 SLINE / 2007 A4 SLINE / 2001 A4 /
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    For #1, grayed out menu item, ambient lighting, it's grayed out for me but what does it do anyway? It's not like we have a bunch of LEDs secreted around the interior.
    Dec 01 2006
    S .NJ
    Think i wanna try - Dim LED strip on turn signal (side markers disabled) whn i get my ecodes installed. Anyone else have this done. How ya like it?
    Jan 12 2014
    Houston, TX
    I hated the wink, so was glad to find the setting to turn off the wink. But dimming is better, as it makes the orange indicator light more visible. Best of both worlds. I don't mind that it completely disables the sidemarkers. They are an eyesore anywAy.
    2020 Q3 Prestige | Gray Metallic | OBDeleven Mods
    2018 S5 Prestige Coupe | Daytona Gray Pearl | ECS Tuning Spacers 12.5/15 | OBDeleven Mods
    2016 TTS Coupe | Mythos Black | OEM Audi Logo Puddle LEDs | VAG-COM Mods
    2012 A5 Prestige Coupe | Daytona Gray Pearl | H&R Spacers 15/20 | H&R OE Springs | OEM Chrome Exhaust Tips | Hoen Xenonmatch Fogs | FL Shift Knob | Interior LEDs | De-badged | VAG-COM Mods
    2011 A4 Premium Plus | Daytona Gray Pearl | VAG-COM Mods
    Aug 04 2010
    Queenz/Westchester
    I've done the dim and I like it. You really can't tell unless your looking for it, but then it becomes apparent. Did it on both our B8's.
    Dec 01 2006
    S .NJ
    Nice!! Im prob gonna do it. I likes!!
    Dec 01 2006
    S .NJ
    Haha yea. But if you buy ecodes def no more orange sidemarker ;)
