Results 1 to 3 of 3
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    misfire is back! can anyone help with these codes?
    Ugh after a few months of the car running perfect the misfire is back but its different than before?
    Before the car was misfiring and back firing and bucking really hard, turned out to be the ICM was too close to the turbo and was overheating, fixed that problem and put new plugs in and the car ran perfect. A few days ago the car would randomly misfire and sound like a subaru. Its not popping and backfiring like before but it will run rough and slow for a min or 2 and the CEL will flash then it will run totally normal again? It has been doing this off and on for a few days now.
    here are the codes i pulled
    5 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16687 - Shareware Version. To Decode all DTCs
    P0303 - 35-00 - Please Register/Activate
    18014 - Shareware Version. To Decode all DTCs
    P1606 - 35-00 - Please Register/Activate
    P0300 - 35-00 - -
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    P0300 is random misfire. P0303 is Misfire Cyl 3. So start there. Check your plug gap, wires leading to cyl 3 coil pack, etc.
    I just had the same issue last night. P0303 Misfire Cyl 3. So I'm doing the same as you. I didn't get p0300 though... Any chance that is left over from your last issue? Did you clear your codes?
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    How old are your coils?
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
