Results 1 to 9 of 9
    Senior Member Two Rings tim04USPa4's Avatar
    May 19 2012
    Greenville, SC
    Intermittent Non-Start Issue...Any Opinions?
    Alright, so I apologize for the long winded question in advance.
    I am having an intermittent non-start issue. The car will turn over perfectly fine, however wont start. I have plenty of fuel, and pressure, at the fuel rail (checked off the schrader bleed on the rail), and the car has new (less than 500 miles) spark plugs. Coils check out OK as well, and I have Zero ignition or fuel related DTC/MIL's.
    Now all of that being said, my short research has turned up three possible gremlins..
    - Crank and/or Cam position sensor. Could be going out, not firing when it needs to to start? But shows no VAG-COM errors.
    - Another error in the start-up cycle...i.e fuse and/or relay?
    - And the crazy one...coolant sensor.
    So from what I've read, the lower coolant sensor triggers the fan, and also controls the 'cold start' vs 'warm start' mode (i.e. choke?), so is it possible the car is thinking its a cold start, and dumping to much fuel to start? I DO have a MIL for low voltage to the lower coolant sensor...
    Any help would be greatly appreciated. This is starting to get annoying, lol. I'm going to change the coolant sensor tomorrow in hopes that that helps, but I'd like to not have to buy $200-300 in sensors for the Crank and Cam if I do not have to.
    Cheers,
    Tim
    Tim
    11 A4 P+ Avant
    04 USP A4 - Sold :( NEVAR FORGOTTEN
    66 Mustang GT 289
    Mar 27 2008
    Denver
    Replace the CTS and then the Crank sensor.
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    ^This is where you want to start. I would replace the CTS on the flange first.
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    May 19 2012
    Greenville, SC
    Rear flange and sensor were replaced less than a year ago. To my understanding, the rear flange and (upper) sensor, is just for the Gauge Cluster. The lower sensor is the one that controls most ECU and engine functions? I.e. cooling fans, cold vs warm start etc.
    I will switch that lower temp sensor either tonight or tomorrow and cross my fingers.
    Thanks for the suggestions guys.
    Tim
    11 A4 P+ Avant
    66 Mustang GT 289
    Oct 02 2006
    Wadsworth,OH
    Have the exact same issue with my car now. Coolant temp sensor acts as a two way switch, one side sends a signal to the gauge cluster for temp reading the other side sends a signal for starting conditions to the ECU.
    If the ECU is not getting the right signal for cold start you will have a hell of a time trying to start the car.
    My car is currently in the shop getting fixed as we speak, ended up being a coolant temp sensor. I would have changed it myself but I'd rather pay someone to do it since it's a PITA to get to and it's freezing outside.
    Jason
    May 19 2012
    Greenville, SC
    Jason
    Jason - thank you for the heads up! Luckily I got both sensors (from ECS to boot ) way back when I did my rear flange...just got lazy and never changed it . Luckily we have some decent weather right now down south, just need to knock it out tonight.
    Thanks again to everyone for the help!
    Tim
    11 A4 P+ Avant
    66 Mustang GT 289
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by tim04USPa4 View Post
    Sounds good! Thanks for the order! All of us up north are jealous of your weather haha! When I go to pick my car up tonight they will be really prying that money out of my hands as it really is tough to accept paying someone for something you're 100% capable of doing, but due to the climate it's a no go.
    Jason
    Veteran Member Three Rings B6_Dolphin's Avatar
    Apr 10 2005
    PNW
    On my '03 1.8T, the cold starts were fine, but warm starts > 30 minutes of sitting would cause a no-start condition on the 1st turn, and then it would start on the 2nd turn every time.
    I changed the crank sensor, despite no codes. It fixed the issue.
    2023 RS5 Coupe - Ascari Blue/Black; Mods: IE A2A IC, 034 Strut Brace, ECS Poly Trans Mount, APR CF Intake, EuroCode FRT & RR STB + Endlinks, DTE Systems PowerControl X & Pedalbox Pedal Tuner, AskCarbon Steering Wheel, ROW Tailights
    2021 SQ5 S/B Prestige - Daytona Gray/Black
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by B6_Dolphin View Post
    That's usually the difference between the CTS and the CPS. CTS will often cause cold starting issues, where as the CPS will cause the warm start issues. Not saying its always that black and white you should still pull codes regardless.
    Jason
