Results 1 to 9 of 9
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: B6/B7 S4 Front & Rear Lightweight ECS 2-Piece Rotors!
    Light on weight. Long on looks. ECS Tuning 2-Piece front & rear brake rotors combine the natural advantages of a cast iron braking surface with the weight savings and rapid heat dissipation of an aluminum hat.
    Cast iron-gray and durable matte black hats create an eye-catching contrast that accents painted calipers behind open-faced alloy wheels.
    These beauties have all the extras: black anodized hats, cross-drilled and slotted brake faces, and unlike OEM, directionally vaned rotors for better cooling and heat dissipation over stock.
    Features include:
    • Aluminum hats: To save weight, each rotor ring is bolted to a lightweight aluminum hat made from high quality 6061 aluminum, and hard anodized with an attractive matte black finish that is both durable and corrosion resistant.
    • Gray cast iron rings: Long known for its wear resistance and stable friction characteristics, cast iron is favored for brake rotors due to its ability to absorb and dissipate large amounts of heat.
    • 2-Piece construction: Conventional rotors are unable to cope with the stress of drastic heat fluctuations and are prone to warping. ECS 2-Piece semi-floating rotors allow the radial expansion of the rotor ring - preventing warping.
    • Heat treated: Heat treating further reduces the tendency for rotor cracking by reducing internal rotor stresses.
    • Directionally vaned: Conventional S4 rotors are straight-veined, and rely on an inefficient centrifuge-like effect to evacuate hot air from within the rotor. ECS 2-Piece rotors feature curved, directional vanes that accelerate air away from the rotor at a higher velocity, leading to consistent, rapid cooling.
    • Drilled and slotted: 2-Piece rotors are cross drilled to promote cross ventilation for even more improved cooling as well as slotted to clean brake pads and carry away water and brake dust. Cleaner brake pads result in faster, more consistent stopping. Drilled holes are chamfered while slots are machined with a ball end mill - both to prevent cracking that may be present on improperly machined rotors.
    • Overall weight savings: This particular ECS 2-Piece rotor weighs only 18.6 lbs compared to a stock S4 rotor at 25.65 lbs. Lighter rotors reduce unsprung weight and rotational mass to improve both braking and suspension performance.
    • Manufacturing quality: Non-friction ring surfaces, including internal vents, are painted to resist salt and other corrosives. Ground braking surfaces ensure rings run parallel, and pads bed easily.
    We make stopping look good
    Fits:
    Audi B6/B7 S4 (2004-2008)
    Jason
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    **Directionally veined:**
    Maybe "vaned". Not to be confused with bloodletting.
    Old Geezer, formerly known as Stud Muffin
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by QIKRNU View Post
    Thanks Webster ;)
    Jason
    Jun 18 2010
    East of Cincinnati
    Thanks Webster ;)
    Jason
    You're welcome. One tries to do what one can.
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Any future group buys?
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Sep 09 2011
    2011 Chevy Duramax, 1999 Mazda Miata
    Chardon, OH
    Quote Originally Posted by S4orgy View Post
    I think Jason said in another post of theirs that they (unfortunately) do not do group buys
    RIP 2004 S4 built by Gellner Engineering Racing Engines
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by aroderick56 View Post
    That is correct.
    Jason
    Senior Member Three Rings blocke's Avatar
    Jul 26 2013
    1990 BMW 325i (sold), 2006 VW GTI (sold), 2006 A4 S-line (sold), 2014 Jetta SportWagen TDI
    Temecula, CA
    Question: Do 2- piece rotors get resurfaced like traditional rotors when the time comes? Or must you just buy new rings, and if so at what cost?
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by blocke View Post
    For existing 2-piece rotor customers we will offer complete replacement rotors at a discount. Complete meaning assembled brand new hats and rotor rings.
    Jason
