Results 1 to 7 of 7
    Deactivated Four Rings
    Aug 30 2013
    2014 Toyota Highlander Limited, 1999 Mercury Grand Marquis GS-HPP
    Panama City Beach, FL
    Bumper support replacement
    I'm replacing a bumper support tomorrow. Is there any reason that I can't use bolts instead of rivets, like perhaps a clearance issue? I've got tons of bolts and nuts in my scrounge I can use, but no rivet gun laying around.
    Oct 16 2008
    South Florida - Ft Lauderdale
    First, you will need an heavy duty rivet gun to install the OEM rivet. Don't even try with a regular hand pliers.
    You can use screws but it will be a little struggle to install the nuts, especially the inner ones
    Phil
    Aug 30 2013
    Phil
    As long as there's no fitment issues if I use bolts, then that's what I'm going to do. I just wanted to make sure using them wouldn't cause issues when I went to put the bumper cover back on. Thanks, Phil.
    Oct 16 2008
    Nah, nut will be inside the crash bar and bolt head on top, no issues
    Use large washers under the bolt head to protect the plastic
    Aug 30 2013
    Yup, will do! I'm going to use a nylock nut to secure it - that should keep everything tight.
    Mar 24 2013
    Oakdale, CT
    I use bolts on mine with no issues.
    -Adam
    Aug 30 2013
    Sweet. That's music to my ears.
