Results 1 to 13 of 13
    Mar 02 2014
    Replacing turbo, advice needed
    My turbo is leaking oil and causing some issues. My cat is f****ed and I have oil literally in my exhaust. It's drivable for now, I still get some boost but my oil level needs to be at a minimum. Anyway I don't have a lot of $$$ to drop on this thing in the coming months, but the turbo will need to be replaced and I would love some advice. I'm not big into mods but TBH new K04 turbos are selling less then the K03, I can find them for around $300-$400 on ebay. My local junk yard has a refurbed K03 off a 2000 or 2001 passat for $300. Can I use a K04 turbo w/ exhaust mani without having to change out my injectors and get chipped?
    Dec 15 2011
    Edmonton Alberta
    Oops sorry... edit!
    -Richard-
    2009 Rabbit. 1961 VW Beetle Canadian Std. 2012 Ram 1500.
    Darsh Import/Dubsport Inc... My very own VW/Audi parts and service shop
    Certified VW/Audi Tech 20 years +
    Mar 02 2014
    Quote Originally Posted by Dubsport Inc View Post
    You will definately need a tune/injectors for a k04 upgrade!
    Yeah, was a long shot but just checking. So again I'm not into upgrading my horsies, I guess the $300 junker is my best bet for now. I just can't justify spending 5-6 bills on a new replacement Dorman or cheap ebay brand.
    Oct 02 2006
    Wadsworth,OH
    Actually you can bolt up a K04 and run stock tune and stock injectors no problem. If you want to optimize the K04 you would need to chip it and depending on the tune, run different injectors.
    As long as you are running stock boost levels you can use a K04 on the factory programing. A K04 is just slightly larger than the K03 and has a slightly different compressor wheel design. In terms of air flow it wont push much more air than the K03 at stock levels.
    Jason
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Quote Originally Posted by Mister View Post
    You can in fact run a K04 with the stock injectors and tune, but will not notice any performance gains. That said, the $3/400 K04's you are seeing on ebay are most likely not BorgWarner units and, for lack of a better term, are junk. Stick with a reputable manufacturer (Garret, BorgWarner, BAE Systems, Honeywell, etc.)
    2019 SQ5 Prestige
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    Quote Originally Posted by texasboy21 View Post
    x2 would go with an rebuilt oem rather than Chinese upgrade copy especially if not utilizing the gains
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Active Member Two Rings A4LEX B6ECK's Avatar
    Apr 18 2013
    So Cal
    a buddy of mine bought a godspeed k04 from ebay ~$450 and it blew on him after a few weeks. dont buy cheap Chinese turbos!!!
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    I was in the same position and bought a FT21...for 1500 you can have a kit for you.
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
    Feb 28 2014
    South Carolina
    I have a used ko3 the one I took off my car when I upgraded to my ko4 if interested
    Mar 02 2014
    I'm still a month away from doing the replacement however checking KO racings's replacement k03 turbo on Ebay for about $300 shipped brand new. I don't expect to get the overall reliability and performance of a brand new OEM but if they're a decent replacement brand I might opt for that instead of a used K03 off a 2001 passat. I figure the yard hasn't disassembled it, so I would need to take it to a machine shop to have cleaned and I expect a lot of wear on the impellers.
    From what I was able to find out about KO Racing, they are based in US but whether or not they import from China I will need to clarify. I can't find any comprehensive reviews on KO so if anyone has any input it would be appreciated.
    Mar 02 2014
    Quote Originally Posted by Quattro kev View Post
    PM me with price shipped to L6B1B5 Canada. I'll get back to you.
    Mar 02 2014
    KO Racing got back to me and stated their Audi/VW turbo is build "overseas" - so yeah, cheap chinese copy for sure. No thanks.
    Feb 28 2014
    South Carolina
    I also have a used k03 that came off my car when i put my k04 on. And FYI you don't need to tune to run a k04.
