Page 1 of 3 123 LastLast
Results 1 to 40 of 118
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    LED Reverse Light DIY B7
    Hello everyone,
    Here is a little DIY I put together a few days ago to add LED's to your reverse light.
    You can use any LED (of course the proper ones to fit your model and housing) to get this job done.
    Here are some steps to follow. This has been discussed here, but I wanted to add a few pictures.
    step 1: Removing screw cover
    step 2: Remove screw holding tail light housing
    step 3: Don't pull the tail light housing from this angle. You will brake the two tabs holding it on the left side
    Use this tool and pry it to get it loose or a small screw driver
    step 4: remove the housing
    Step 5: Unplug the harness from the housing
    As you can see mine was done but I wanted to tape it up better.
    step 6: locate the brown and blue with red stripes wires. My pin shows # 4 and 6 (drivers side housing)
    step 7: These are the wire tap used.
    step 8: use above wire taps to tap into the two wires from pin #4 and 6
    Step 9: Closer view
    Step 10: Adding the reverse wire (blue/red stripes) in the wire tap
    Step 11: Adding step 10 with one side of the wire coming from the resistor, see black cable
    Step 12: Crimp them tight together to make a solid contact/Connection
    step 13: Do the same as above but you are going to use the brown wire.
    Crimp the brown wire with the other wire coming from the resistor.
    step 14: you should now have something like this
    As you can see there are two wires each coming from on of these connectors (wire taps)
    Brown with black and blue/red stripes with black. The black cables are the wires coming out from the wire bound resistor. See pic in Step 7.
    Step 15: tape everything back together.
    Step 16: mount your resistor to the chassis of the car for additional heat sink
    Try to average and mount it a little low so the housing can fit without touching it.
    You should now end up with this.
    If I forgot something please don't hesitate to chime in.
    I'm just trying to share and help the community as it has done for me.
    This was done on the driver's side housing, but it also pertains to the passenger side. The pin numbers will be different, but the colors of the wires should be the same.
    Enjoy.
    Waiapasi2006
    Established Member Two Rings amar26's Avatar
    Feb 23 2011
    Oakville, ON
    is it noticeably brighter when reversing in the dark?
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by amar26 View Post
    Yes, if you have a reverse camera you will see the difference.
    Waiapasi2006
    Veteran Member Three Rings blingaling's Avatar
    Feb 12 2011
    05 ninja 636(RIP)
    NEPA
    Awesome! Where did you get the leds from?
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by blingaling View Post
    I got them from a local store, but they are tons online.
    Waiapasi2006
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    These are better then the ones I used.
    Mine are the same brand, but has only 18SMD those have 24SMD I just had them laying around.
    Waiapasi2006
    Veteran Member Four Rings jsandor91's Avatar
    Jun 10 2011
    dead hookers
    South Jersey
    Do yours ever stay partially on or did the resistor fix that ? I plan on trying out a projector led bulb next
    Sent from my Nexus 4 using Tapatalk
    Quartz Grey B7 A4 Quattro 6MT
    Maestro + Epy Tuned / GTX2867r / S3's / Spintech Non-Resonated 3 Inch Exhaust / Cold Side Synapse DV / TR18 + 2.5" Piping / Hpfp S1 Pump
    Bi-Xenon retrofit + Fly's leds / ST Coils + Rsb / 18x9.5 Miro 111's
    Dat Der Build Thread
    Coming Soon: Boost Manager +, Drakes Performance Stage V Clutch
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by jsandor91 View Post
    Mine stay on... slightly.
    Jun 10 2011
    dead hookers
    South Jersey
    Quote Originally Posted by Hugh@EuropaParts View Post
    Do you have a resistor and what style bulb do you have ?
    Oct 31 2011
    B8.5 S4, B9.5 SQ5, MK4 Jetta
    Redmond, WA
    The ones i tried do and they flicker when put in reverse!
    "if I wanted magic phallus shaped objects that didn't make me go any faster, I would just hit the gay club downtown, no need to spend $400." - Mec
    S4 Build
    Aug 22 2010
    Piscataway, NJ
    No resistor... just a reg 1156 LED bulb, not the projector type.
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Mine used to be on slightly , but the resistor fixed that.
    Sent from my Tapatalk App.
    Waiapasi2006
    Feb 25 2011
    Seacoast NH
    AWESOME!!! Thank you, OP!
    Feb 25 2011
    Seacoast NH
    Just adding this here for anyone that needs to know what bulb is what:
    http://www.audizine.com/forum/showth...nt-%28B7-A4%29
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by wildcat333 View Post
    You got it.
    Waiapasi2006
    Oct 31 2011
    Redmond, WA
    Any local place these resistors can be purchased ?
    S4 Build
    Nov 25 2011
    2018 F80 M3 ZCP, 2007 RS4
    Ive found the projector ones to be much brighter. I tried a few different types.
    http://r.ebay.com/FfuHOo
    Oct 31 2011
    Redmond, WA
    Quote Originally Posted by AJacksA4 View Post
    X2 the exact ones i have
    S4 Build
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by AKOeuro View Post
    The BLUE housing metal or plastic isn't visible through the clear reverse plastic, is it?
    Jun 10 2011
    dead hookers
    South Jersey
    I would like to know this as well I almost purchased like $20 ones
    Feb 25 2011
    Seacoast NH
    I wonder if these would be good?
    They have projector style on the front of the LED bulb, but also allow light from the sides (which would reflector on the mirror reverse area of the tail light).
    http://www.ebay.com/itm/2x-1156-Whit...574c54&vxp=mtr
    Oct 31 2011
    Redmond, WA
    Slight reflection but only at an angle! Doesn't bother me
    Sent from my SGH-T999 using Tapatalk
    S4 Build
    Aug 19 2012
    Audi A4 B7 3.2
    Boston MA
    Would they even fit?
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by Pashody View Post
    I dunno
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Try them and post back.
    Waiapasi2006
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Try any automobile stores that deals with leds in your area.
    I know the radio Shack here don't carry them. You might be lucky where you're at.
    Waiapasi2006
    Nov 25 2011
    Yeah the blue is a bit visible, but you know me, it goes well with my setup. If you want a more OEM look they make them in silver or you could always paint them. The other lights you found should be even better if they fit, the more LEDS the merrier.
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    To answer your question I tried to park in a dark spot to take this snap shot.
    Waiapasi2006
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    There are brighter ones out there. I just used these because I had them for a while sitting.
    The picture was taken without applying brakes, so no extra lighting from the brakes lights.
    They will soon have leds in them too.
    Waiapasi2006
    Veteran Member Four Rings 2pointOh's Avatar
    Dec 08 2013
    Buffalo, NY
    Could you use 3m tape to mount the resistor? Drilling holes always worries me about rust.
    2006 A4 2.0T 6sp. JHM Stage 2 93 Oct. JHM TP-DPY to S4 Exhaust. GFB DV+. AFE Dry Filter Drop-In. 034 Engine Mounts. ST Coilovers. ECS RA4 LW SMFW and RS4 Clutch.
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by 2pointOh View Post
    I'm not to sure how well they would hold up with the heat. The chassis will help as a heat sink which is better.
    Waiapasi2006
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by waiapasi2006 View Post
    Yeah understandable. I guess you could just put some grease where you'll drill
    Sent from my XT1080 using Tapatalk
    Oct 31 2011
    Redmond, WA
    Im gonna check it out! Thanks
    How hot could the resistor get? I mean your reverse lights are on for what 5 maybe 10 secs?? I think double sided tape should hold up okay
    S4 Build
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    No grease here.
    Waiapasi2006
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Go for it!
    Waiapasi2006
    Dec 08 2013
    Buffalo, NY
    Good point! I'm going to try that soon, once I get maintenance done.
    Feb 25 2011
    Seacoast NH
    Double sided tape should be fine. I have it on my drl resistors that get 400 degrees hot and I've had them for over two years.
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Interesting.
    Waiapasi2006
    Feb 25 2011
    Seacoast NH
    Interesting.
    Yeah. As long as the metal you apply it to is clean, you should be good to go. I had to redo it within one week of installation because my surface was not clean apparently. I removed the 3M tape, cleaned it with rubbing alcohol, and reapplied.
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    If it works for you, go with it.
    Waiapasi2006
