Page 3 of 3 FirstFirst 123
Results 81 to 118 of 118
  1. #81
    Veteran Member Four Rings 2pointOh's Avatar
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by mr_pulido88 View Post
    I used that for the resistors on my LED DRLs and they worked for me!
    Yeah I feel like it would be fine! Just clean the metal well and hit it with some isopropyl alcohol before you apply it
    Sent from my XT1080 using Tapatalk
    2006 A4 2.0T 6sp. JHM Stage 2 93 Oct. JHM TP-DPY to S4 Exhaust. GFB DV+. AFE Dry Filter Drop-In. 034 Engine Mounts. ST Coilovers. ECS RA4 LW SMFW and RS4 Clutch.
  2. #82
    Feb 25 2011
    Seacoast NH
    I might do the 3M tape + the tapping screw. Thanks, OP.
  3. #83
    Feb 25 2011
    Seacoast NH
    I also watched a million youtube videos last night, and might attempt soldering these wires together. Off to Radio Shack to get a beginners soldering kit!
  4. #84
    Established Member Two Rings mr_pulido88's Avatar
    Jul 02 2013
    Antelope Valley
    Quote Originally Posted by wildcat333 View Post
    I'm thinking of doing the same but with the DRLs.
    I already did the transistor process twice twice and still get the bulb out error, it get's really annoying -.-
    If you do, post pics or something, I've never soldered before lol
    2007 Audi A4 2.0T Dolphin Gray S-line
    "God has put obvious limitations on our intelligence; but none whatsoever on our stupidity"
  5. #85
    Feb 25 2011
    Seacoast NH
    Test wire
  6. #86
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by 2pointOh View Post
    Would 3M double sided not work? I no like drilling.
    You could, I think some members has done that.
    Waiapasi2006
  7. #87
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Test wire
    Looks good wildcat, don't forget your heat shrink when your about to do your initial install.
    What are you soldering though if I may ask?
    Waiapasi2006
  8. #88
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Did you install them correct?
    Waiapasi2006
  9. #89
    Jul 02 2013
    Antelope Valley
    Quote Originally Posted by waiapasi2006 View Post
    I'm pretty sure I did; I don't always get the bulb out warning, it comes and goes. I think the wires are not making a solid connection, as if the metal tab is not touching the wire fully.
  10. #90
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Some of the wire tabs inside are for larger or should I say ticker gauge wires. You should double check that as well.
    I bought two packs as in my DIY and noticed it.
    Waiapasi2006
  11. #91
    Feb 25 2011
    Seacoast NH
    The idea is to solder the resistors in for this reverse led project. I also bought the heat shrink, so I think I'll be good to go. Might try this today.
  12. #92
    Jul 02 2013
    Antelope Valley
    Oh I didn't know that... I'll double check it then, thanks!
  13. #93
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    YGI.
    Waiapasi2006
  14. #94
    Feb 25 2011
    Seacoast NH
    So I finally went to install my revere LED lights and resistors today, but ran into an issue. My RIGHT( passenger side) reverse light was flickering, and threw a bulb-out error. I swapped to bulb to the LEFT side, and the LEFT bulb to the RIGHT side. The flickering did not follow the bulb, and was still flickering on the RIGHT side of the car. Unfortunately, I had already soldered the wires together and don't know what else could be the issue. So I have two questions:
    1. Odds that my issue is a bad resistor? Could such a thing make my bulb flicker and throw the error code?
    2. Besides cutting the wire and starting over, is there any "easy" way to remove solder? Suggestions here?
  15. #95
    Nov 25 2011
    2018 F80 M3 ZCP, 2007 RS4
    Cut the wire and start over, you need to test whether its the connection first. The bulb is flickering because the resistor isn't making a solid connection or its the wrong resistance. With a resistor properly wired in, you shouldn't even see a "bulb out" when you take out the bulb.
    Hope this helps.
  16. #96
    Feb 25 2011
    Seacoast NH
    Oh great idea. Let me try that. Thanks!
  17. #97
    Feb 25 2011
    Seacoast NH
    OP, can you think of any reason why the 50W, 6ohm resistor might not be working for me on my passenger side? It seems to work fine on my driver's side. I removed both reverse bulbs, and only get the error on the passenger side. I even replaced the passenger side resistor with a replacement 50W, 6ohm resistor, and then another. But the issues persist. I'm really at a loss as to why I still have these issues. I even cut out all of my old soldering from the passenger side and rewired it properly and just have electrical tape on there now.
    I ordered a pair of 25W, 10ohm resistors based on this older thread - http://www.audizine.com/forum/showth...need-resistors
    As a reminder, this is the bulb I have:
    http://www.ddmtuning.com/Products/1156-5W9x5630W
    "High Power 1156 Reverse LED Bulb.
    Each bulb used 1 x 5W Cree bulb inside a projector lens and 9 x 5630 SMDs on the side."
    I need help
  18. #98
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    I need help
    Put back your regular bulb and see if your issue still persist.
    Waiapasi2006
  19. #99
    Feb 25 2011
    Seacoast NH
    I did. I put back both of my regular OEM bulbs.... and no flickering or bulb-out errors (no issues exist).
  20. #100
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    did you try swapping the LEDs?
    Waiapasi2006
  21. #101
    Feb 25 2011
    Seacoast NH
    I see you you said you removed both bulbs. Do you mean by swapping them from left to right and right to left?
    If not so,try it with the led bulb first. Then,the resistors. something has the fault. Bulb, resistors or connections.
    I have swapped the new LED bulbs. The problem did not move with the new LED bulbs, leading me to conclude the new LED bulbs are fine.
    When I said I removed the bulbs, I did so for testing purposes - per your prior reply to my issue. The Driver's Side (DS) did not throw a code with no bulb installed. The Passenger Side (PS) did throw a code with no bulb installed.
    I cut out all of my soldering because I feared that I messed that up somehow since I have little experience in soldering. Since I made these cuts, I had to extend both the brown ground and the blue/red power wires. I used 18 gauge wire for this. All of the splices/connections are solid, and I have them currently taped together nicely. I am just at a loss as to what it could be on this one side. If my DS had similar issues, I would be more confident that it was an issue with BOTH resistors. But since my issue is only with my PS, I am confused still. I'm going to attempt to install the new 25W/10ohm resistor next week when the package arrives in the mail. Until then, I'd still like to pick everyone's brains on this issue. Thanks.
  22. #102
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Very strange for only one side to give you this error. Why didn't you use the wire taps instead of cutting and soldering?
    Did you also try swapping the resistor (DS) to (PS). Leave the DS with out a bulb and resistor to see if anything happens.
    Waiapasi2006
  23. #103
    Feb 25 2011
    Seacoast NH
    I didn't use wire taps because I wanted a more permanent and sealed connection. I could swap the DS resistor over but then I would have to mess up that whole side that is working-- including cutting everything out of the solder etc.
  24. #104
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    You shouldn't have sealed or taped up everything until it was good and working. I was suggesting this because it could be the resistor is at fault too. Just saying.
    Waiapasi2006
  25. #105
    Feb 25 2011
    Seacoast NH
    I should have done a lot of things. But live and learn. I'm not concerned about removing a little tape at this point. I had to tape up everything to continue to test this issue so I wouldn't have exposed wires touching each other or metal parts of the car.
  26. #106
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Yep. Well post bak if you got it resolved with your new items.
    Also, try to do the swap as I had mentioned to see if that works.
    Waiapasi2006
  27. #107
    Dec 07 2006
    San Francisco, CA
  28. #108
    Dec 07 2006
    San Francisco, CA
    Help! Avants have 2 blue wires with red stripes? Which one should I tap into?
  29. #109
    Dec 07 2006
    San Francisco, CA
    Took a chance. Looked at how the wiring was laid out on the light holder. Guessed that it was the blue/red wire next to the brown wire. And it worked!
    Just an FYI if an Avant guy comes here looking for answers.
  30. #110
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by europaisch View Post
    I can't see your Image OP, but I'm glad you got it resolved.
    Waiapasi2006
  31. #111
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    This will be for others in the future who wants to explore .
    Waiapasi2006
  32. #112
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    Sorry to bring this thread back from the grave.
    However, if I wanted to change all the bulbs (brake/taillight light bulbs and indicator/blinker bulbs) to led bulbs will this one resistor be all I need ?
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
  33. #113
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by DanKing View Post
    I had seen a video on YouTube with a guy showing off his leds. I saw a bunch of resistors. You could try it though. That was my intention at first, but then I went with a complete led tail light. I chickended out
    Waiapasi2006
  34. #114
    Aug 14 2014
    California
    Can you hunt down that video ?
    What led tails did you get ?
  35. #115
    Feb 25 2011
    Seacoast NH
    x2
  36. #116
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    When I was looking for some info, it popped up on YouTube.
    I'm sure if you search you'll find something related to it. Here are my tail lights
    x2
    As I wrote ^.
    Waiapasi2006
  37. #117
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Update.
    I uploaded the pictures missing from photobucket I luckily still had.
    Waiapasi2006
  38. #118
    Junior Member One Ring ZumFax's Avatar
    Jun 03 2020
    Estonia
    Hello, guys i have a problem with my b7 and reverse led lights, so i installed Led reverse lights (P21W) with 50W 6ohm resistors. Everything works when car is turned off(key turned position 1 and in reverse gear), but when car turned on and reversin my parking sensors go crazy, just peeping and if i brake then sensors go quiet.
    So, do i need another resistors/leds, or because sensors i cant use leds??
    Thanks..
