Results 1 to 15 of 15
    Jan 24 2014
    United States
    Questions about a test pipe install and heated seats
    Greetings, AZ people!
    Two questions for you guys:
    What is the easiest way to install a test pipe with a lift available? If i drop the whole exhaust , do I need to remove the pass side motor mount?
    And
    The heating element in my drivers seat takes forever to heat up and only heats up very mildly. My passenger one works perfectly. Is there a way to swap the heating elements?
    Veteran Member Three Rings Koldham's Avatar
    Aug 12 2012
    Walnut Grove, Georgia
    i actually just installed my test pipe. i dont have a lift but i dropped the entire exhaust and pulled it back at the same time (you will see)until the bottom bolts were in line with the underbody. then just put in those bolts and slide the whole thing back up then attached it to the turbo
    1997 A4 1.8QTM AEB Pearl DD
    Deer Strikes:0 HELLASTOCK...ish WTB: pearl white body panels.
    1973 Ford Maverick Project Car(first car)
    200 I6 -> 302 V8, 3spd column shift, 8.8 with traklock. Bright Ass Orange.
    Aug 18 2013
    United States
    1) It's super easy, just take out the cat and swap in the test pipe. You might want to loosen the exhaust from the hangers to make it easier to line up.
    2) Not sure, but don't think you can remove the heating element.
    Jan 24 2014
    United States
    Yea. Its the CAT to DP bolts that are a major pain in the ass
    Aug 12 2012
    You might be able to undo your down pipe connection and not have to drop the entire exhaust. Otherwise the passenger tire has to come off. I cant see any other way to do it. Somebody wiser than I may have a better way
    Jan 24 2014
    United States
    Another question. Would 17 inch wheels with 225/55/17 tires fit on a b5? im lowered on h&r springs
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    Disconnect the cat from the turbo, disconnect the DP clamp, wiggle and lower the whole assembly down enough so that you can reach the 3rd bolt more easily to separate the cat from DP. The nuts are welded to the cat so you do not have to back them up.
    You can fix or replace your heated seats. What often happens it that the wires in the heating element get broken over time, the fix is to open the seat up and fix the wiring or replace the element. You could also swap the seat cushion from passenger to driver.
    http://www.audizine.com/forum/showth...up-for-a-B5-S4
    http://www.audiworld.com/tech/elec177.shtml
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Jun 10 2010
    Quote Originally Posted by LaCross View Post
    Nah b.
    Jan 24 2014
    United States
    What tire size am i looking at for 17 inch wheels? 215/45/17?
    Oct 30 2009
    Miami, FL
    45 is ideal, 50 might fit based on offset and tire width (I ran 225/50 for a while but there was barely a couple mm between the tire and upright.) If you're in the rust belt like me chances are your cat-DP bolts are toast so you'll have to pull the whole thing, I was actually able to get mine out through the top.
    2018 S5 Coupe - stock for now
    Dec 12 2012
    Niagara Falls
    Heated seats are a huge pain in the ass to do I found. I tore apart a spare I got from a parts car and it wasn't as smooth as I expected. As well, the heated element is glued to the foam so you can't really take it off and replace it. You need to replace the entire seat base foam and all.
    I decided to just swap the entire seat instead or take it out and have a guy that knows how to do upholstery with the proper tools like hog ring pliers to put it back together right then reinstall it myself.
    Jan 24 2014
    United States
    Is there any ebay brand smic that is available? for the mk4 jetta there is one that's only $130. Could this be modified to fit?
    Oct 30 2009
    Miami, FL
    From what I've seen in pictures the biggest difference between mk4 and b5 SMIC is the endtanks and in/outlets, in the B5 they both point straight up and in the MK4 one points up and the other's at an angle. Take a look at some pictures and you'll get the idea. Unless you can tig weld, or know someone who will do it for free it's not really worth it since you'll end up spending more than a good FMIC that will flow and cool much better than an ebay SMIC.
    Jan 24 2014
    United States
    Yea but with a fmic you need to chop up the bumper and move the ps cooler
    Jan 24 2014
    United States
    What about using one of the S4 intercoolers? On one of them, both inlet/outlet are pointing in the same direction. Im thinking with some hose work maybe this could fit?
