As the title says, looking to make some room in my garage. 1 owner, clean title!
photos will be added shortly!
2007 Audi A4 2.0T Quattro 6spd
Metallic Silver
32,xxx miles
Exterior:
S-Line front bumper
S-Line Trunk
Bi-Xenon Retrofit
LED License plate bulbs
Suspension:
H&R S4 Coilovers
Hotchkis S4 f+r Sway bars
Interior:
Podi Dual Gauge column Pod
Podi Boost gauge
Zeitronix AFR Gauge
LED Interior bulbs
HKS EVC-4 Electronic Boost Controller
Engine:
HTA 3076R .63 AR
Tial 38mm v-band wastegate
Pagparts cast stainless steel v-band manifold
Mahle 83mm 9:1 pistons with steel pins
Brute 144mmx20mm H-beam rods
Coated rod bearings
Ferrera 1mm oversize intake and exhaust valves
Fereara titanium retainers
Ferrera valve springs
ARP main studs
ARP head bolts
ARP crank bolt
Fluidampr pulley
ASP Motor Mounts
INA Engineering intake manifold
APR High Pressure Fuel Pump
RS4 injectors
HPFP 155bar Performance Rail Valve
Custom 3" Downpipe
Custom cat-back exhaust
Clutchmasters FX400 ceramic 6 puck
Clutchmasters billet steel flywheel
JHM Short Shifter
JHM Linkage Upgrade
Garrett 900HP Core
Devils Own Water/Meth w/ 2.5 Gallon Tank
BSH Race Catch Can
DoTuning Custom Tune
Extra inlcuded parts Parts:
Non S-Line Trunk
Spare S-Line bumper without fog grilles (track bumper)
Spare S-line Grille
Spare filler plate
Spare ECU (w/custom tune)
Dell D-Series Laptop w/ flashing software and handheld flash loader
BEST OFFER
PM ME
List Date: 2/13/2014
For more info, click here to view the original listing: Feeler: Metallic Silver Stage 3 B7 A4 6spd, Low Mileage
This item is no longer available.
