Results 1 to 4 of 4
    Active Member One Ring PhxPhil's Avatar
    Jul 31 2013
    1923 Ford roadster, 54 Chevy Belair,59 Olds Rocket 88, 1970 Toyota Landcruiser V8. 71 BMW R75 Cafe
    Phoenix
    New guy - Wheel tech - American Salt Flats fit A4 Quattro?
    I am a bit of a hotrodder and I have a 2009 A4 Quattro and really want to see if these wheels would fit offset-wise.
    http://www.summitracing.com/parts/ar...FQJrfgodNiQAFw
    I know the bolt pattern won't fit, but it may be possible to get a custom wheel made from them.
    http://static.summitracing.com/globa...e-470_w_ml.jpg
    Brand:American Racing
    Manufacturer's Part Number:4707958560
    Part Type:Wheels
    Product Line:American Racing VN470 Salt Flat Special Gray Wheels
    Summit Racing Part Number:ARE-4707958560
    Wheel Diameter:17 in.
    Wheel Width (in):9.500 in.
    Wheel Material:Aluminum
    Primary Wheel Color:Gray
    Wheel Finish:Gloss
    Manufacturers Wheel Series:American Racing Salt Flat Special Series
    Backspacing (in):6.000 in.
    Offset:+19.00mm
    Wheel Construction:2-piece
    Beadlock Functional:No
    Beadlock Included:No
    Lug Nut Seat Style:Conical seat - 60 degree
    Hub Centric:No
    Center Cap Included:Yes
    Valve Stems Included:No
    Quantity:Sold individually.
    Notes:Due to the custom order nature of these wheels they cannot be canceled or returned once an order has been placed.
    Wheel Bolt Pattern:5 x 5 1/2 in.
    Jul 31 2013
    Phoenix
    Wow. No response at all?
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    17x9.5" ET19 is about 25mm further out than most people seem to be running with 9.5" wheels. If you're trying to go for the "poke and stretch" look then you might be able to make things work assuming they actually clear the calipers.
    Jul 31 2013
    Phoenix
    Thanks for the Reply. I see you are from Redmond. I grew up in Everett.
