Results 1 to 4 of 4
    Active Member One Ring Nate_M's Avatar
    Jan 02 2013
    A6 2.7t, 04 Corolla
    Grand Prairie
    My temp guage shows hot when my car is not!
    My temperature guage shows my car is running hot and my coolant level light is on and the coolant is full. I have had a vary small coolant leak for about 6 months but hedge only had to top of the coolant twice in that time frame. The guage is one notch away from the H. I left the engine ruining and took off the coolant cap and it bubbled a bit and was fine so i don't believe it's really ruining hot. My fans do run but the ac doesn't come on. If i turn on my heater it's working fine but the temp guage didn't budge.
    Could this be a simple temperature sensor or coolant temp sensor bad or anything else? Please help my tech is backed up and can't get me in for 2 Weeks... 2001 A6 2.7L
    Jun 22 2013
    coolant temp sensor(easy fix) and or coolant level sensor that is built into the coolant resivor so you have to buy a whole new expansion tank.
    Jan 02 2013
    A6 2.7t, 04 Corolla
    Grand Prairie
    Quote Originally Posted by Vinnie981 View Post
    I changed the sensor but broke the clip that holds it in... the dealer is closed so i hope AutoZone has it...
    Active Member One Ring VAVAMATT's Avatar
    Feb 19 2014
    1969 cutlass Supreme
    Ottawa, Ontario
    I have same problem with the same car.... Changing temp sensor too...
