Results 1 to 6 of 6
    Active Member Two Rings LOMartin's Avatar
    Jun 18 2013
    Miami/Savannah
    Rear Seat re-install Part# 4L0 886 373
    Audi 2011 S4 Sedan
    I had to pull out the rear seats to take care of some spilled water.
    I removed the baby seat plastic covers, then yanked on the front of the rear seats as expected the front two clips broke (Part# 4L0 886 373).
    The dealer provided me with new clips, I installed them in the holes and pressed the seats back down. Yes I aligned the rear of the seat with the seat-belt buckles and re-installed the baby tie down plastic covers.
    The rear seat is loose around the clips. I can not remove the seats as they are clipped in but they are still loose.
    any suggestions or tips on what I did wrong?
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    S4 coupe?
    I didnt know you could remove the rear seats on a S4...
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Apr 04 2012
    MSP
    What's an S4 Coupe?
    Jun 18 2013
    Miami/Savannah
    Yes yes, simple mind fart. its a sedan.
    Apr 04 2012
    MSP
    Other than just double checking your work I'm not sure what to recommend. Unfortunately I've heard that after removing rear seats from a car like that they never fit the same as from factory... you may have to get help from the dealership?? I hate rattles so I'd probably pay the hour labor they may want to give it a once over...
    Aug 05 2015
    Tallinn
    Quote Originally Posted by MrFunk View Post
    Just removed rear seat for cleaning. I know, it`s possible to do all the cleaning without removing also but the lower part was not fixed very well and I wanted to address this issue also. As a result, I think I can help a little with this "never fit the same" problem.
    My seat clips came off from holes and stayd fixed to seat. As a result the hole edges were a little bent upwards. Marked with red. Pushed those back.
    Plus the wire frame beneath the cushion was also bent in the fixing area. On the right you can see wires already pushed pack, on the left undone.
    When installing seat back, align carefully wire loops and clips (be sure that clips are also installed as on first pic - carpet between special groove) and push it back. I stepped on exact clip position with my heel, it didn`t "click" when tried to do it with hand. Considering this, I recommend bending hole edges and wire frame back quite a lot. And evenly on both sides. If it`s too much, it simply will not click and you can do something about it. If bent too little, it will click easily but you might get seat still not fixed firmly.
    And next time I need to do this, I will get new clips from dealership. I guess I was lucky they didn`t brake this time. 4L0886373 should be code for my version. European 2010 A4 Avant that is.
