Results 1 to 6 of 6
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    1.8T Oil leak, front of engine
    Having an issue tracking down an oil leak, thought someone might be able to lend a hand on some insight.
    I can see oil on the oil pan, front motor mount, near the power steering pump. I have 3 or 4 drops on the ground in the morning after it sits during the night. Valve cover gasket is good and dry around it. Any ideas? Cam sensor seal maybe? I haven't had a chance to tear into it, hoping someone could give me some direction where to look.
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Check the oil filter location. Could not be screwed on enough. At the same time when oil changes are performed, sometimes the filter base can become loose and leak around the block to oil cooler mount point.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Aug 06 2008
    Indiana
    I'll check it out, had an issue with the oil cooler gasket before a while back. Would that make it all the way to the front of the engine. It's only on the front of the motor.
    Jan 16 2006
    LA CA
    Who knows, you are not giving us much to work on so I am going for simple to spot and down low. On the front: well, it could be power steering too. It could also be upper camshaft seal or lower main seal too. The real answer is you need to rip things apart and start looking. Anything other than that is a guess on our part.
    Jul 07 2013
    Kent OH
    Something else you could try to locate the leak is clean up the oil that is on whatever. You could be getting oil splashing back to parts while driving. Also check around the oil filter as said before. These cars are notorious for leaking around the oil cooler gasket which just sits right about the oil filter.
    Established Member Two Rings JohnathanAvant's Avatar
    Dec 20 2012
    Raleigh, NC
    Quote Originally Posted by nynoah View Post
    I've got a small leak from my camshaft seal that I thought was a head gasket. Tear off the front and follow the trail. Have plenty of time and plenty of wine.
    034 phenolic intake manifold spacer/034 pcv replacement hoses/ECS test pipe/APR turbo inlet pipe/2.5 custom exhaust from test pipe to muffler/Magnaflow mid-muffler/Vibrant rear muffler/TT diverter valve/GIAC tune/Neuspeed sport front and factory sport rear springs w/Bilstein sports shocks
