Results 1 to 13 of 13
    Registered User Four Rings
    Oct 29 2013
    Q5 3.0T, MK6 GTI S3+, MK6 R S3
    Lebanon, PA
    ***APTuning Service Specials - Timing Belts & More - Great Prices in Central PA!!***
    Here at APTuning we want all of our customers to get their cars ready for the soon approaching spring(even though it may not feel like it some days ha) and get your service done so you are good to go for the upcoming show season. Most of the enthusiasts are already planning trips but we all know there is nothing worse then your car leaving you sit on the side of the road because of procrastinating on preventive maintenance.
    Therefore we are offering discounts on some specialized services. This sale covers timing belts, general service, and alignments. All prices include parts, labor and tax to complete the standard job.
    For general service receive 10% off associated labor charges. Save money on everything from a simple oil change to a clutch replacement and everything in between. Simply mention you saw this post on Audizine and get your discount!!
    Timing Belt Service - Prices listed below - includes timing belt, tensioners, metal impeller water pump(where applicable), accessory belt, coolant, and taxes. By far the most procrastinated scheduled service on any vehicle is the timing belt. Usually due simply to the high costs of inflated dealer prices. This is an extremely important part of preventative maintenance that if fails will easily multiple the repair costs into the thousands of dollars. Factory interval schedules are usually between 90k-105k but we highly recommend replacement around 70k-80k due to a lot of know failures before the factory specs.
    B5/B5.5/B6/B7 Chassis A4/S4/Passat
    • 1.8T 20v (all engine codes) - $645
    • 2.7T/2.8 (all engine codes) - $730
    • 3.0 V6 (all engine codes) - $930
    • 2.0T FSI/TFSI (all belt drive engines) - $590
    Since we know a lot of Audi owners may have a Vw as a second car we pass the savings along there as well
    MK4 Chassis Golf/Jetta/GTI/GLI/20th/337/Beetle/TT
    • 1.8T 20v (all engine codes) - $590
    • 2.0 8v(non-BBW engine) - $460
    • 1.9 Diesel(TDI & PD) - $700
    MK5 Chassis Jetta/GLI/GTI/A3 - MK6 Golf R
    • 2.0T FSI (all engine codes) - $645
    • 1.9 Diesel (PD engines) - $700
    A/C Service- $125 complete, includes check, vac test and recharge, freon, taxes. (covers most Audi/VW vehicles) Most of us have been there, first hot day of spring, sitting at red light and start feeling toasty. Turn the A/C on and gets marginally cool at best. Why wait to address the system once you realize it isn't working? Get it done now so when that day comes you can simply put the windows up and be comfortable.
    Alignment Service - $70 Front Wheel, $100 All Wheel, includes labor, printout and taxes. (covers most Audi/VW vehicles) Alignment is probably one of the most overlooked services to be done to a car. Many people feel if the car goes straight the alignment is fine which is a terrible misconception. A car can drive straight but still have alignment issues which could negatively effect a cars handling or destroy tires. An incorrectly alignment can keep you from getting the performance your suspension or tires are capable of. This should be done once a year or whenever irregular tire wear is noticed.
    ***We specialize in lowered cars and can do virtually any, no matter how low!!!
    Senior Member Three Rings Jhad's Avatar
    Aug 03 2012
    '11 Touareg
    SEPA
    Good shop. If you live close by check them out
    Oct 29 2013
    Lebanon, PA
    Quote Originally Posted by Jhad View Post
    Thanks for the props, we are new to audzine and is def appreciated.
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    How often do you guys see tire wear on lowered Audi's WITH adjustable upper control arms.....?
    Oct 29 2013
    Lebanon, PA
    Quote Originally Posted by B72011 View Post
    If the alignment is within spec then the wear should be normal and is dependent on miles and how the car is driven, being lowered should have no bearing on that.
    Oct 29 2013
    Lebanon, PA
    Get your appointments scheduled, calendar is filling up quickly!!
    Oct 29 2013
    Lebanon, PA
    Time to spend that income tax return on something useful!!
    Oct 29 2013
    Lebanon, PA
    Oct 29 2013
    Lebanon, PA
    Oct 29 2013
    Lebanon, PA
    Should be a great day, get out and enjoy yourself.
    Oct 29 2013
    Lebanon, PA
    Bump
    Oct 29 2013
    Lebanon, PA
    TTT
    Oct 29 2013
    Lebanon, PA
    Sale is almost over anyone want in on this before time is up? :)
