So I decided to make a new thread for my 2014 build since my original thread (http://www.audizine.com/forum/showth...le-Turbo-setup) exploded into such a huge thread.
Currently a work in progress but here's the recipe so far (At least what I can tell you ;-))
3.0 Stroker Engine:
JE 83MM FSR Pistons - 10:1 Compression Ratio
JE Tool Steel Wrist Pins
Integrated Engineering Rods
ARP 625+ Custom Aged Rod Bolts
ARP Custom Main Studs
CNC Ported 2.7 Cylinder Heads
+1MM Supertech Intake Valves
+1MM Supertech Inconel Exhaust Valves
Supertech Solid Lifters
LOBA Solid Lifter Cams
83.5MM Head Gaskets
Billet Dry Sump Oil Pan w. Integrated Girdle
Peterson 4 Stage Dry Sump Pump
Borg Warner EFR 9180 Turbo w 1.05 AR T4 Exhaust Housing
Quick Spool Valve
Direct Port Nitrous
Megasquirt 3 Standalone Engine Management System
There's more but I forget right now... lol
Now some pretty pics for you to enjoy for now...
