Results 1 to 7 of 7
    Sep 15 2013
    United Kingdom
    difference between s line and non s line suspension
    Hey guys as above just wandering what the main difference us between the two cars
    Reason I ask is I'm looking at lowerng my car and a lot of websites are saying for example 35mm drop not for non s line models
    Obviously the s line is lower than the non s line. Would the springs not fit at all or would they work out at different sizes on different car?
    Aug 03 2013
    Renton, wa
    They would fit just fine, I think they are stating you won't get the same amount of drop coming from an s-line, compared to a non. Due to the s-line being lower already
    '22 X3M - Stock...for now
    '14 S4 P+ DSG 034 Stage 2+ ECU/TCU 57.7/190, AWE Touring, MercRacing, AWE S-Flo, Stoptech STR-60 - Gone but not forgotten
    '14 A4 S-Line Sport Package 6MT - Totaled
    '12 Tiguan SEL 4MO.
    '03 Mustang Cobra "Stock"
    Senior Member Two Rings Warren S's Avatar
    Jan 13 2009
    is a portal to another dimension...
    Carson, CA (L.A. area)
    Here in the U.S., the S-line (sport suspension) is a 20mm drop. In Europe, I believe I read somewhere that it's 30mm.
    2011 B8 A4 Avant quattro: S-line, Prestige, Monza silver.
    2008 B6 Passat 3.6 VR6 4motion, BBS.
    '97 F150 Supercab Flareside 4X4 off-road.
    Jun 23 2013
    PacNW
    AFAIK, in the US on the B8 there really is no "s-line" suspension. The S-line package comes with the sport suspension which is a 20mm drop.
    If you put lowering springs on oem non-sport shocks, you will reduce their life, perhaps severely. Hence the warning.
    Dec 01 2011
    if you are getting lowering springs like H&R OE or similar, then it will lower your car to the same height, s-line or not. you only are lowered if you have the sports package which has the sports suspension, same as the S4 has, and is lowered like 20mm from non-sline height, but the thing is with for example H&R OE's which give a ~32mm drop from non-sline, will give a ~12mm drop on a sports suspension (which is 20mm lower already), but you'll end up at the same height.
    IG @theshawon
    Aug 19 2013
    Europe
    In Europe "S-Line suspension" is 30mm drop, "sport suspension" 20mm drop
    Dec 14 2013
    Wilts, UK
    To add to that, in the UK, the S-Line model gets the 20mm "sports suspension" as standard. The 30mm "S-line suspension" is an option, why they done it like this? gawd knows.
    I have the 20mm drop "standard" on my S-line and it's OK, firm, good for keeping body roll down etc, but not hard enough to jarr.
