Results 1 to 40 of 54
    Senior Member Three Rings jordan122345's Avatar
    Jul 11 2011
    Lochbuie, CO
    What southbend clutch disk is this??
    I bought this used off a forum member and I am curious what actual clutch disk this is. The seller said southbend told him it would hold 600tq. So hoping it will be good for.my tial 770's. Any help is appreciated as always. Thanks ron
    Feb 21 2011
    WA
    A full face disk for 600wtq out of 770s? That seems like a stretch.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I wouldnt call that full face, but I agree 600tq is prob pushing it.
    Is that all you got or is there a pp too?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Feb 21 2011
    WA
    Quote Originally Posted by zillarob View Post
    It looks just like a "full face" FX400 to me. Agreed, not full faced like an OEM/OEM+ replacement though.
    Jul 11 2011
    Lochbuie, CO
    We should be around 550 to the wheels tq and hp in Denver. And yeah came with a sachs pressure plate and lightened flywheel also
    Jul 11 2011
    Lochbuie, CO
    https://s3.amazonaws.com/pandlmotors...ineclutch2.jpg
    So the guy I got it from had a stage 3 endurance and on his first dyno pull after installing it slipped and southbend sent him the disk pictured above and said that it could handle up to 600tq
    Nov 16 2010
    WetSide, WA
    Quote Originally Posted by waB5S4 View Post
    I wonder how different the 8puck and 6puck disks really are.
    I think when it comes to how much they hold, it is about the clamp of the pp and surface area of the friction material on the disk. Basically psi.
    Prob same pp and surface area looks similar between the two. Would be interesting to drive them back to back to see if there was any difference in engagement or holding.
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    Have you contacted southbend? Shown them this picture and asked. They will know before most
    Jul 11 2011
    Lochbuie, CO
    I tried to look for fx400's and this looks close but not quite. I asked Scott at advanced automation and he thought maybe a southbend stage 4 dxd clutch but I don't think that's it but I could be wrong
    Jul 11 2011
    Lochbuie, CO
    Not yet that is the next step
    Jul 18 2009
    They'll set you straight. Wonder if its the "extreme" street? The extreme drag is a 6 puck but it looks like the extreme street is a "full face"
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Has 770's. Buy's used 'unknown' clutch. I'm willing to bet that's not a SB friction plate.
    Nov 16 2010
    WetSide, WA
    My guess is it is a sb.
    I just put an fx400 8puck in, looked very similar, but oem center.
    Jul 11 2011
    Lochbuie, CO
    The guy sold it to me as an extreme stage 4 southbend so I am just making sure that it will hold I did check with my mechanic first I was just making sure
    Mar 14 2012
    PHL | BOS | SEA
    Quote Originally Posted by jordan122345 View Post
    You're right, I was wrong. Hope it holds for you.
    Jul 18 2009
    My guess is it will have better luck than that endurance that likely glazed after one pull. Kevlar :thumbdown:
    That extreme is advertised as 600 tq. Not sure if that's same for both the full face and 6 puck?
    Nov 16 2010
    WetSide, WA
    Id concede full circle, but that disk is def not full faced.
    Jul 18 2009
    True. That's why "full faced". Forgot to carry that over to last post...see #11 :p
    Nov 16 2010
    WetSide, WA
    Quote Originally Posted by happy2B5 View Post
    Interesting.
    So if it had 6 pucks (ala fx400) riveted to it instead of 8, you would still consider it full faced?
    Do you think it would perform any differently if the backing plate had the star shape?
    Jul 18 2009
    Nov 16 2010
    WetSide, WA
    Wait, I think Im understanding the quotes now
    Jul 18 2009
    I'm not challenging anything really.
    I am curious and want to know if the ability to hold power is as much a product of the friction material itself as the disc design? Or all of the above?
    Nov 16 2010
    WetSide, WA
    Lol ya, I didnt catch the quotes.
    Jul 18 2009
    I did "know" what clutch it was though. Hahahaha :sly:
    Nov 16 2010
    WetSide, WA
    My guess is the star shaped backing ones are just to lighten up the disk a bit and wont affect engagement or holding.
    Weight prob has an effect on shifting at different rpms.
    I do wonder what the difference would be between two disks with the same surface area and friction material, but say 4 larger pucks instead of 8 smaller.
    Jul 11 2011
    Lochbuie, CO
    Okay so it sounds like it really is a stage 4 extreme so are we thinking it will hold with 550tq or no
    Nov 16 2010
    WetSide, WA
    The only thing I can add is maybe call Jon up at Southbend and see what you need to do to get that clutch setup as new.
    They can do it for you, but he is a good dude and prob give you the numbers if you want to tackle it yourselves.
    Jul 11 2011
    Lochbuie, CO
    So are you saying buy a new setup or send in mine to get reworked
    Jul 18 2009
    Yep. I'd call up SB. Like I said, it is advertised up to 600 tq. I'd still want to share the pics you have with them and get their take. Only way to know for sure at that point is slap her on and go! Should make for a fun ride.
    Nov 16 2010
    WetSide, WA
    I cant tell from the pics how worn it is, but say .005 is worn off of each of the 4 surfaces in there for .020 total.
    You could knock .020 off the step and be back to new, or maybe even better because it has already gone through the high wear break in.
    Jul 11 2011
    Lochbuie, CO
    Okay I emailed Jon at southbend. And the guy I got it from said he had only 400 miles on this disk
    Sep 11 2009
    NE
    put the PP against this fw+cluthc disc without putting any bolts in and measure the gap between PP and FW. This will give you an idea about life of clutch left. Brand new (before break in) measures ~ 0.1" on these set ups. As said above, if you grind FW's step up a bit, you will get more spacing between PP and FW and therefore more life out of the disc. But that is dependant on how much friction pad's thickness is (clutch disc surface to top of pad times two, or measure thickness of disc at pad and then at the disc itself and subtract one from another), measure that too.
    Nov 16 2010
    WetSide, WA
    CM was a hair over .080 brand new (and confirmed correct by CM), but the SB should be quite a bit more.
    I think this is the reason for so many posts on short lived CM fx400 setups.
    Wouldnt surprise me if your SB lasts more than twice as long as its CM counterpart.
    Jul 11 2011
    Lochbuie, CO
    well I really hope you are right so another question on this clutch is how close or far off is it gonna drive compared to stock driveability. And what do you think a ballpark figure $$ on resurfacing it would be
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    That is most likely an FX300 or FX350. Difference being material (fiber tough) and not obvious to the eye. I have an FX350 in 240mm and love it. I can take off like a stock car. It is not jerky like an on off switch. I don't think it would hold the power you are wanting to make. At that level you need a FX850 Super Single or more.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Active Member One Ring ALE81's Avatar
    Apr 16 2012
    South Bend, IN
    The closest comparable clutch is the stage 3 drag, rated at 550 ft.lbs. I would change disks. Call SB on Monday and ask for Dave. Tell him Drew sent you.
    Nov 16 2010
    WetSide, WA
    You prob dont need to have the whole thing done, maybe just cut the step a tad bit. Wouldnt surprise me if a machine shop would do it for 40ish.
    Do like julex said and get us a number. If it only has 400mi on it you prob dont need to touch it.
    May 16 2008
    South Texas
    That's a regular stage IV. The Stage IV extreem has an X by the SS tag.
    That looks like a very worn ceramic disc too..
    Jul 11 2011
    Lochbuie, CO
    Quote Originally Posted by Scotty@Advanced View Post
    So the pressure plate was from a stage 3 endurance and the original clutch disk was too till it slipped on the first dyno pull so he sent the disk in and they sent him the disk I have pictured. So will that pressure plate work out or no
    Veteran Member Four Rings PinoyS4's Avatar
    2018 catalunya RS3
    sf bay area
    I would not risk the clamping force of that pressure plate for tial 770's
    work hard, play hard[;)
