Been doing my research the last couple of days and I think I have a plan of attack...
As it turns out, there are two different output shaft seals used in the 01X/02X transmissions:
Oil seal (up to manufacture date 29 08 4)
without additional dust lip.
Part # 02X409400
This oil seal also requires a 1.4mm shim.
Part # 016311391A
Oil seal (from manufacture date 30 08 4 onwards)
with additional dust lip.
Part # 02X409400A
I had to check the manufacture code which can be found right next to the transmission part number on the bottom of the transmission:
The manufacture code is decoded as follows:
My code is GJW11024
The first three letters are the transmission code: GJW
The first pair of numbers are the day: 11
The second pair of numbers are the month: 02
The last number is the year: 4
So, this means my transmission is a GJW manufactured on February 11th, 2004.
Compare this info to the above dates correlating to the seals. In my case, I need the seal without the dust lip and also need the shim.
Which sucks because I bought the one with the dust lip. :(
My official plan of attack is to go to Harbor Freight and buy myself a 12 ton press. I can't buy the 6 ton press because the frame is too small to fit the whole differential in there to press out the flange. It's going to be much easier for me to press out flange, install the seal and shim, and press the flange back in rather than drive into town and have someone else do it. It sucks that I have to pay $129 for the convenience, but it's a necessary convenience and I'm sure this won't be the last time I use that press.
I plan on writing a DIY for all of this.
