Results 1 to 16 of 16
    Jan 03 2007
    Fayetteville, AR
    GT2871r T3 vs T25 hotside
    Im currently in the process of going big turbo, I bought at GT2871r with a T25 .64ar flange. However I'm having a hell of a time finding a manifold. A friend is willing to give me a super deal on an ATP T3 Manifold. So I have been considering swapping the turbo to a T3 4 bolt and going to an external WG.
    Ive not really found much info on how this effects the turbo (spool time, power ext) I know that spool will be slower, just a matter of how much. Anyone running a T3 flanged 2871r? Would love to hear some impressions vs its T25 counterpart.
    Thanks
    Ethan
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Im using a t25 .86 or whatever, and the spool is fairly slow, but suppose to be equal to the .63 t3. the .63 t3 is the most common though
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Dec 05 2007
    Use the ATP ebay T25 clones for cheap. Many run the ebay clones with no issue. If it's going to crack, it's going to crack. ATP brand or not.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    If I were to do it over, I think a T25 with internal wastegate would be so much easier to plumb. In the future if you ever wanted to go EFR, T3 starts at the 7064.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Stay with the T25.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Feb 06 2013
    WV
    For the gt2871r the t25 is more then fine and .64 is best suited to it. Later if you want to upgrade their is other options like gt3071r or gt3076r. Hell you can wven do a gt3582r and use all garrett parts with a t25 flange.
    I have run the eBay ATP clone with no issues... just lap the mating surfaces...
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    I like external wastegates not plumbed back into the exhaust (open wastegate). sounds mean as fuk
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Oct 17 2009
    alonE, Pa
    ^ that it does.
    STEVE
    Feb 06 2013
    WV
    I have a 3067R that I am thinking about running open dump on. I have actually NEVER heard an open dump. Where I work I could not get by with it..... Then again I could drive it without getting into it.
    Oct 17 2009
    alonE, Pa
    Yeah, take her easy going there and leaving. Get on it when your off the property.
    STEVE
    Dec 13 2010
    FL
    Quote Originally Posted by zandrew View Post
    I used to run open dump on my last 2.0 gt35t b5. I had atp mani with the atp screamer pipe that comes out of the bottom. most plumb it back into the exhaust, i didnt. let me tell you, when it opens, its friggen awesome. sounds like englishtown raceway park lol
    Feb 06 2013
    WV
    Quote Originally Posted by viceprp View Post
    I don't think it wold be possible. Where I work I pass Lambo's, Ferrari's, Porshe; I have seen a Veyron. I get some hairy eye balls and those super douches (not all) will rev it up a lot of times when i go by. Its hard as it is now, once I get it all together it would be an impossibility.
    Dec 05 2007
    Miltant Grunt's car when he had a B5 A4
    Dec 13 2010
    FL
    ^yeah, thats the sound I was talking about!
    Feb 25 2013
    MKIII Jetta,Integra GSR built B18C1T, Mazda RX8
    United States / Georgia/ SE
    ^ Thats crazy how much this sounds like a B or K series honda engine.
    Florett Silver Metallic, Black Optic, Sport Diff, B8.5 S4
    Dec 13 2010
    FL
    Quote Originally Posted by U_know_me View Post
    I used to think the same thing when I had open dump..lol
