Hello ladies and gents!
Been using the forum as a reference tool for many years now without registering, but I've finally run into an issue that has me pretty well stumped, so here I am.
Picked up an 01 A6 Avant (2.8 ATQ) a couple years ago, and been wrenching on small issues ever since. Couple of weeks ago, after letting the car sit over a weekend, I went to start it up. Car fired up, ran for about a second, then died. Cranking it again failed, and after just a couple tried, the battery (about 3 months old) died. Jumped it, and still no dice.
My first thought was "Well, it started at first, so...fuel delivery?" Hooked the batt up to a mobile jumper, and flipped the ignition to "on". Fuel pump primed just fine, and after a couple cranks, I pulled the plugs. Yep, def getting fuel to the cylinders. Pulled the throttle body to make sure there wasn't an issue there, again, seemingly no issues. I would assume that leaves spark. Haven't had a chance to test it yet, but I would assume if I've got fuel and air, spark must be the issue.
In addition, replaced the coolant temp sensor (O-ring had almost dissolved into the coolant line), and tested the engine speed sensor (it was operating fine). Still nothing.
Finally, to figure out what could be killing the battery so quickly, I hooked up the multimeter, and saw something is draining the battery, and fast.
I would assume this all points to a short, but I'd really like to avoid spending the time and energy running back and forth pulling a fuse, getting up to check a test light, then going abck and pulling another (also heard that method doesn't work well on these cars).
Any suggestions or thoughts would be greatly appreciated!
