Results 1 to 14 of 14
    Senior Member Three Rings Ake219's Avatar
    Mar 13 2013
    Fairfax, VA
    About to Install Coilovers...
    Anyone have experience in DIY install? I haven't installed suspension myself, but I've helped friends do them a couple of times. I'm either going to have a local mechanic do it for $240, or give it a shot by myself... depending how cocky I feel. Anyone with expertise have any words of wisdom to contribute?
    __________________
    2009 Audi S5 :: QuartzGreyMetallic :: BlackAlcantara
    [4.2 v8 :: quattro :: 6sp :: tech :: navi :: b&o]
    [air lift autopilot v2 :: awe track + nonres dp's :: ecodes :: wheels tbd]
    Established Member Two Rings Epixman's Avatar
    Sep 16 2013
    Northern Virginia
    I'm not much of a help, but care to share who would install it for $240 in this area? I just ordered some coilovers for my S4 and need someone to install them when I get them. I'd rather pay for the coilover install, Normally I'm a DIY guy, but after doing coils on my B7, I told myself next time I would just pay for someone to do it.
    2014 Monsoon Gray S4|6MT|STaSIS Challenge Exhaust|Vogtland Coilovers|Ecodes|
    Veteran Member Four Rings i1overice's Avatar
    May 09 2013
    Loads of junk.
    Northern Virginia
    Quote Originally Posted by Ake219 View Post
    They can be a pain in the ass depending on how old your car is. This could be due to rust and build up. Im assuming you are putting this on your 2009 S5. There are a few ways to install the coils, either from the top or bottom, both would be better with two people. If you trust the mechanic, 240 isn't a bad price at all. I would and do pay a mechanic I know to do mine.
    Current - 2017 Honda Civic EX-T
    Sold - 2010 Ibis White S5
    Veteran Member Four Rings d.p's Avatar
    Nov 08 2006
    F80 M3
    Annapolis MD
    Quote Originally Posted by i1overice View Post
    Ditto. You can DIY but you can't beat $240.
    Mar 13 2013
    Fairfax, VA
    Thanks for the advice guys. The $240 was actually a quote from a friend who does local work out of his garage, so I'm assuming it's a friend discounted rate. That said it wouldn't be a fancy/official/certified job, that's why I was deciding between that, or attempting it myself.
    __________________
    Veteran Member Four Rings krazyboi's Avatar
    Oct 24 2006
    NoVA
    What's the DIY look like? After help installing my old coils, I would attempt to do it on my own next time.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    ~Johnny / JT
    Current: 2019 Florett Silver A5
    Old: Audi A3 3.2 VR6 BT Build, 2016 Pure White GTI
    CleanAudi.com feature
    Mar 13 2013
    Fairfax, VA
    Here's one I glanced over last night, but seeing as it's from the manufacturer, it has a lot more torque specs and safer guidelines than other DIY's I've read that are more "improvised". e.g. the KW manual says only use compressors, other member DIYs be like "pop that shit out with a pry bar"
    http://bd8ba3c866c8cbc330ab-7b26c6f3...horizontal.pdf
    __________________
    Nov 08 2006
    F80 M3
    Annapolis MD
    ECS has one for H&R coilovers but they are all pretty much the same. There are some things that can be a pain in the ass but its certainly doable as suspension is not rocket science by any means. I did it with a couple buddies on one of old S4 avants and had no issues other than it being time consuming.
    I also paid $370 to Induktion to install my H&R's on my current S4 because I just didn't want to mess with it.
    Apr 18 2011
    NoVA
    $370's not bad, did that include alignment? Got a set of H&R's in my living room waiting to be installed once I get rid of my winter setup here in a few weeks hopefully.
    '12 Audi A5 Prestige S-Line | Ibis White | TI Sport Package | 6MT
    APR Stage 1 | AWE Dual Outlet Exhaust | H&R Coilovers | Eurocode Meisterwerk ASTS | H&R Spacers (15mm Front / 20mm Rear) | 35% Tint
    Mar 13 2013
    Fairfax, VA
    Quote Originally Posted by mihixson View Post
    Dual DIY install!?
    __________________
    Veteran Member Three Rings OB1's Avatar
    Jun 25 2010
    Baltimore
    The front's are relatively easy to do, but getting the rear springs out are a PITA. Just don't take the rear subframe assembly bolts all the way out or you're going to have a bad time.
    Using jackstands might take all day, so I'd suggest finding someone who has a lift.
    '12 MG A4 Avant
    Veteran Member Four Rings Ms.S4's Avatar
    Apr 25 2012
    S4/S5/A7...we love Audis!!!
    For $240 in this weather, I would be lazy and do DIY on another mod.
    IF you think your friend will apply the same level of care as you would!
    Stage 2 S5 cab - *brilliant/magma*sports diff*BCForged*H&R*Pirelli*AWE*Built with Love <3*
    Apr 18 2011
    NoVA
    Dual DIY install!?
    Haha, yeah, think I'm going to leave this one to the professionals.
    Nov 08 2006
    F80 M3
    Annapolis MD
    No alignment, with its another $100 or so. I have a place a little closer to me that I prefer for alignments.
