Results 1 to 4 of 4
    Dec 08 2013
    Markham
    '03 a4 oil sludge low oil pressure. "cam chain tensioner noise" 325K kms (video)
    We've had this problem for about 2 mnths~ now and now its time to let it go. Before that we changed the cam chain tensioner and then put in like 40% diesel and rest 5w-30. Now it started up just fine and did not make the noise at all for its duration (5 minutes this was just for the cleaning) I'm thinking that the oil galleries or oil pump/pick up tube is clogged and the thinner oil/diesel mixer got through fine. I'm just wondering before we part out/sell the car should we add some really thin visc. oil and see if the car runs? Now it's out of the warranty time for the oil sludge recall and I don't think we can drop the pan (unless it's easy to do so?) This is how it sounds currently
    http://www.youtube.com/watch?v=_oTThLviQWA
    Dec 25 2004
    Earth
    They is a proceedure previously posted here that you could find if you searched....
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Dec 08 2013
    Markham
    Quote Originally Posted by MikTip View Post
    Already did just not sure if it is worth it or part it out cause it's already at 325K kms on it
    Dec 25 2004
    Earth
    Quote Originally Posted by a4quattrob6 View Post
    Do what you think is best for you
