Results 1 to 2 of 2
    Mar 24 2013
    Montreal
    SD Card in MMI 3G+
    So I basically copied over my iTunes to the SD card. I did this a long time ago and the shuffle feature worked perfectly fine. Now, for some reason, it won't shuffle the songs. It will only shuffle the songs in each individual folder. I try to change the settings to repeat none, shuffle. But once I click on shuffle, repeat all comes on. Then it doesn't shuffle through all the songs. Anyone know of a resolution?
    Senior Member Two Rings Jmstrag's Avatar
    Aug 15 2010
    try putting a song in the main folder.......play that song and then select shuffle all. It should then shuffle everything, including all the folders.
