Results 1 to 6 of 6
    Active Member Two Rings rmg0685's Avatar
    Oct 05 2008
    East Haddam CT
    Replacing front wheel bearing
    I have a front wheel bearing that needs replacing , the replacement looks pretty straight forward the only thing that I wonder about is the removal of the wheel bearing off of the hub. Has anyone done this themselves and if so how did they remove the wheel bearing.
    | 2010 Audi S4 | 6MT | Bang & Olufsen Audio | 19" 5 Segment Wheels | Carbon atlas inlays | Eurosport CAI | AWE Pedals | RS4 Grill | ROC-Euro Short Shifter | Tint: 20% | EPL Stage 2 | 034 Trans Mount |
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    I do this on my race car a few times a year and it's not a huge undertaking except for needing a really strong torque wrench for the center bolts and time to take everything apart. I would also make sure nothing needs to be pressed in because that can sometimes hold things up. Do you have a workshop manual for the job?
    Edit: Or the post directly above mine. Clearly my typing speed isn't good this morning.
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
    Oct 05 2008
    East Haddam CT
    Thanks I found that thread in the search just wasn't sure if it was the same for the b8 s4
    Established Member Two Rings Doc Masher's Avatar
    Apr 28 2012
    USA Southwest
    You will want to get the torque specs for the b8 task before you start this job. I know for a fact that some of the bolts you will remove for the task are one time use bolts, and axle bolts are highly stressed parts that require precise torque to assure safe reliable results. There are some brake DIY threads that will get you some of the brake related torques, as for the other torques, hopefully some one will chime in with some technical procedures for those tasks.
    Good luck with the r&r.
    How many miles are on your car? Do you track it? What happend to the old bearing?
    2011 S4 S-tronic, Sports Differential, Titanium Package, Stoptech BBK ST-60 355MM, Alu Kreuz and APR CPS pump with reservoir separator
    Veteran Member Four Rings apexit1's Avatar
    Jun 04 2010
    northern nj
    Axle bolts are 19mm hex. I'd pop the wheel off, take the center cap off, lower car again, loosen the axle bolt and then get started. You'll need a triple square (XZN) i think in 12 or 14 for the bolts holding the actual bearing off. I had to go to a shop to remove them from the hub. Post up your experience for those in the future.
