Results 1 to 9 of 9
Thread: Seafoam Users
    Aug 27 2013
    Philly
    Seafoam Users
    So seafoam was on sale at Autozone and I though, hey why not run a can through the tank. If you do this, dont just add the can to the gas fill neck. USE A FUNNEL! I didnt realize that the top of the neck that is shaped like a cup is actually a drain and probably about half of my can ended up on the ground..... You live and you learn. Just wanted to throw that out there for others, as I know its become standard to foam your car. I guess I got about half of the can into the actual tank.
    Senior Member Three Rings B6cool's Avatar
    Oct 23 2012
    tricycle
    Yes I learned that too. This is why I fill it up very slowly at very small angle, and never get a dripp.
    19" BBS CK wheels, Bilstein PSS9 coilovers, 034motorsport front adj. control arms and rear swaybar, Vw Brembo 4-piston front brakes, b7 rear brakes, StopTech SS Brake Lines, Sprint Booster.
    Buy my parts PM me - for sale b6 s4 front brakes Tyrol sport stiffening kit, kW v1 coils. Usp front valance unpainted.
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    I usually run about 1/2 the can in my tank....and the other half through the intake.
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    Quote Originally Posted by Myst420 View Post
    Same here. Didn't notice a increase in performance though. I think most people do it for the smoke show.
    Aug 27 2013
    Philly
    Yeah it was certainly one of those moments. in my old cars I like to run a full can through a full tank every once in a while. I think the intake exposure is overkill.
    Dec 19 2007
    York, PA
    all you have to do is open your gas cap to figure this one out....theres no way to NOT spill it without a funnel.
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    It's not something I do all the time, but I usually notice a little difference in my mpgs afterwards. It always smokes, but I've found that the worse the car is, the darker the smoke.
    Running it through the intake is also a good way to check for exhaust leaks.
    02 A4 Quattro 1.8T
    Veteran Member Four Rings freeloader700's Avatar
    Mar 23 2012
    '03 A4 1.8TQM
    The Hills, OR
    I put a can in the tank maybe twice a year. Don't really notice much of a difference. They say you can also put it into the crank case.
    WARNING Do not put it into the crank case. My buddy put it into the crankcase on his Camaro and it spun a crank bearing. I also put it in my 5.0 Mustang I had and from then on I blew blue smoke. Maybe its just because we had older cars. I just know I wont risk running it through the crankcase on my A4. There is my 2 ¢
    2003 A4 1.8TQM // Motoza // GTRS // 550cc // TR18T // Forge Splitter // 034 RSB & End Links // V710 Gunmetal 19x8.5
    →→FrankenTurbo F21 BUILD←←
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Quote Originally Posted by freeloader700 View Post
    Seafoam is pretty strong stuff and on an older (untreated) engine it can cause large chunks to break loose and clog the oil passageways, pickup screen, etc. I have used it successfully in the crankcase multiple times without any issues.
    2019 SQ5 Prestige
