Results 1 to 7 of 7
    Oct 13 2009
    toronto
    AEB or AMB Replacement Cylinder Head?
    Hi guys,
    I need some advice.
    My cylinder head is cracked and I cant find a decent AMB replacement locally but,
    I found an AEB so, I was thinking about making the switch.
    I only have a 2871R eliminator & realize that the benefits of the AEB head won't be realized
    unless if rev higher so, now I'm thinking about building the head & getting an INA intake manifold.
    Like everything else on this car, things snowball quickly!
    It looks like to get the valves, springs, retainers, guides, seals, machining, intake manifold & throttle body,
    I'd be looking at about $2000.
    My question is, for $2000 is it worth revving a 2871R to 8000 rpms?
    Would the extra power I'd make be worth it?
    Can a 2871R even keep up at 8000 rpms?
    has anyone seen dynographs of a high revving eliminator?
    Now I'm thinking that if I do build the head,
    I might as well get an EFR.
    Like I said, SNOWBALL...
    Thank you for any input.
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    I rev to 7600RPM with a Garrett 50 trim on my stock AEB head. The point of building the head would be to rev it past 8k RPM mark. I say with your turbo just slap the stock AEB head on.
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Feb 17 2004
    Liberty Hill, TX
    the 2871R hits its peak before the stock redline (6500), revving it out to 8000 isn't going to buy you anything. Furthermore, an AEB head with a 2871R is just going to cost you low end torque with little to nothing in return. I posted a thread on this about a year ago and the overwhelming consensus was to stay with the stock AMB head with the 2871R, even on a 2.0l setup: http://www.audizine.com/forum/showth...a-2-0l-stroker
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Oct 13 2009
    toronto
    Thanks for the info guys, it'll save me a bunch of loot!!!
    Did you stick with the AMB head, Matt?
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Get AMB if possible for the smaller turbos, but if you have the opportunity to get the AEB as a deal go for it because it will be marginal difference if any and actually a loss as Matt said but it will prolly be to negligible to notice.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Veteran Member Three Rings Audiguy1234's Avatar
    Aug 28 2011
    North Chicago
    I would just buy an AEB head. I have had 2 AMB heads crack on me. When I changed to AEB, I didnt noticed a difference in performance, but I had a GT3071r on a stock displacement engine.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by jinxed View Post
    I did. Another factor besides the low end TQ drop is losing SAI, which I didn't want to do given I run a high-flow cat.
