Results 1 to 9 of 9
    Senior Member Two Rings bombdiggity's Avatar
    Nov 16 2013
    San Diego, CA
    Sticking caliper on B8 S4?
    Hey Guys,
    Anyone have any issues with their calipers sticking? I told the used car dealership that my Rear/ Driver rim has much more brake dust than the rest. Their conclusion was to replace the rear pads and rotors as they were out of spec, they guaranteed their work for 6 months but, that tire still has more dust than the rest. I would also note that the rear tires have considerably more brake dust than the fronts. Also the car has been pulling slightly to the right making me think the caliper is sticking as the tires don't appear to be wearing unevenly after a few months.
    Anyone have any experience with this issue on the 2010 B8 DSG S4? I didn't see anything in the forums about sticking calipers.
    Thanks,
    Shawn
    Account Terminated Four Rings
    Mar 08 2010
    San Francisco, CA
    Maybe the rotor is warped but unlikely.
    Jun 13 2013
    2011 Forester XT, 2006 STi, '31 Ford Model A death trap
    Northern Illinois
    You need to check to make sure the caliper slides freely and that the piston bore is not damaged.
    Nov 16 2013
    San Diego, CA
    The rotors and pads are both new OEM for the car. The originals before replacement were cross drilled rotors on the back. So I am assuming this is the third set of rotors on that car.
    Jun 13 2013
    Northern Illinois
    Lets say the rotors were warped causing wear. You would feel a pulsation in the pedal. As I said earlier. Make sure nothing involving the caliper is bound up.
    Mar 08 2010
    San Francisco, CA
    On a 2010 you might be nearing a break job if you're around 50k miles.
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    sometimes when I put on the parking brake after driving in the rain or snow and then try to release it after some time, the rears will stick...is this similar to what you experienced?
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
    Senior Member Three Rings Moto One's Avatar
    Mar 26 2010
    C5 Z06 (going on 17 years)
    Tahoe/Truckee
    You may have some air in the system, or a bad proportioning valve sending more braking pressure to the one rear. Sticking caliper would be very hot after normal driving causing discoloring of the rotor. Or they just put in what ever pads they had and the rears are not a match set? "it could happen".
    Mark
    Nov 16 2013
    San Diego, CA
    Quote Originally Posted by nick71692 View Post
    It seems that it's a possibility. It seems like my car pulls more right intermittently. I stopped using the parking brake for a few weeks as I thought maybe that was a cause, but it still dusts up the left rear tire pretty good. The rear brakes have new OEM rotors and pads. Just wondered if anyone has encountered this issue and what they did to resolve it. I will probably just take it back to the dealership i bought from as they warrantied it for 6 months. I figured their solution wasn't going to work.
    I haven't noticed any discoloring of the rotors, but when I clean the rims every week. That tire is the worst and would explain my car pulling right occasionally. I guess I will take it in. Just not looking forward to driving a 2013 Impala again (their renter).
