Results 1 to 13 of 13
    Oct 31 2011
    B8.5 S4, B9.5 SQ5, MK4 Jetta
    Redmond, WA
    Does anyone know how to unplug these two plugs???
    Sent from my SGH-T999 using Tapatalk
    "if I wanted magic phallus shaped objects that didn't make me go any faster, I would just hit the gay club downtown, no need to spend $400." - Mec
    S4 Build
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    blow torch or hammer should work, if that fails try liquid nitrogen then crack them off
    2008 A4 S-line 2.0T
    JHM Stage 2
    Oct 16 2008
    South Florida - Ft Lauderdale
    You are not supposed to touch these but only the other connector
    You need to pull up the yellow tab and then pull the entire connector
    Phil
    Oct 31 2011
    Redmond, WA
    Phil
    I have to swap over the harness! I figured it out though
    S4 Build
    Oct 16 2008
    Quote Originally Posted by AKOeuro View Post
    You need to pull up (flick) the yellow tab and then pull the entire connector
    Hope your battery is disconnected
    Phil
    Oct 31 2011
    Redmond, WA
    Quote Originally Posted by Schweini View Post
    ........ airbag to the dome haha
    S4 Build
    Oct 31 2011
    Redmond, WA
    Phil
    hahaha stop scaring me Phil! I dont want a face full of airbag on this beautiful day
    S4 Build
    Oct 16 2008
    Disconnect the battery and you will be fine
    No kidding here
    Phil
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    you should always disconnect the battery when working with the electrical components, listen to him lol
    2008 A4 S-line 2.0T
    JHM Stage 2
    Oct 31 2011
    Redmond, WA
    Haha it was disconnected from the get go! I just didnt know i would have to swap over the harnesses. Risky business
    S4 Build
    Oct 16 2008
    Rule #22 once the airbag has blown up
    Phil
    Oct 31 2011
    Redmond, WA
    There will be pics just for you Phil is it normal that my ESP light is on! There is a recalibration of the angle sensor right?
    S4 Build
    Oct 16 2008
    Totally normal
    Take the car for a spin and it will go away
    Phil
