Results 1 to 21 of 21
    Jan 24 2014
    United States
    Best bang for the buck handling mods?
    I do solemnly swear that I did search! I just wasn't satisfied with the results.
    Car info:
    99 A4 TQM , AEB engine
    Lowered on H&R springs only (p/o did it)
    The rest of my suspension is stock
    So my question is,
    For the money, what are the best suspension mods for HANDLING?
    I know sway bars are one. But which sway bar setup is the best?
    97 A4 2.0TQM
    Rochester, NY
    rear sway bar is probably the best bet.
    h-sport?
    Dec 16 2013
    Minneapolis, MN
    Best bang for your buck is good performance driving lessons on a track and good tires.
    Next weight loss, light wheels (less unsprung weight), and new-or-better condition of suspension components (i.e. not much use putting money into springs/shocks/sways when you have bad bushings)
    Then, work on the shocks/springs and sways, adjustable shocks and sways so that you can fine tune your setup. You get what you pay for. Get spring rates that fit your end goal. Ideal spring rates can vary depending on the intended use.
    Finally, stiffen up suspension and chassis mounting points, braces etc.
    I can't stress enough that training will show the most improvement. I took a 2-day driving course put on by Porsche in Birmingham Alabama, we were driving 911 Carrera S's, Cayman S's, Boxster's etc. At the beginning of the course our teachers could have easily bested many of the students track time with the students in a 911 and the instructor in a Volkswagen Eurovan.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    034 Motorsport rear sway bar!
    2001 Corvette (C5) Z06
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    Best bang for the buck? An S4 rear sway bar. You should be able to pick one up for less than $100. Can't beat that.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Quote Originally Posted by Optimusglen View Post
    I can't help myself but I found this hilarious.
    I have the same suspension and did 034 SD Engine & Tranny mounts (less engine roll), control arms (steering was crisp),19mm Rear Sway Bar (less body roll) and JHM Trio (solid shifting).
    The new 034 sway bar is the Bee's knees.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    The funny thing with the 034 rear sway is since there is almost no body roll, when you jack up the front wheel, the whole side of the car comes up.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Jan 24 2014
    United States
    Do I need to replace end links when I upgrade my rear sway bar?
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by LaCross View Post
    Not necessarily. The stock endlinks are plastic and inherently weaker than other options out there.
    I "upgraded" mine to the Meyle HD metal endlinks at the same time I installed the 034 rear sway bar.
    Veteran Member Four Rings AudiB5owner's Avatar
    Sep 08 2011
    B5 A4 1.8T AWM FWD
    Los Angeles, CA
    Wish the S4 RSB would bolt onto FWD without a lot of fabrication. RSB looks like the best suspension upgrade for a start.
    Sent from my DROID RAZR using Tapatalk
    B5 A4 1.8T FWD
    Dec 23 2009
    Boulder, CO
    Quote Originally Posted by MetalMan View Post
    I would and did. The way the endlink bolts are, you probably will strip them out when you try to replace them anyway. I ended just sawzalling mine off when I replaced mine. The top bolt comes off fine, its the lower bolt with the 5mm allen key that strips. If you go the 034 route, i highly recommend the support brackets as well.
    Oct 17 2009
    alonE, Pa
    Quote Originally Posted by Avant Nate View Post
    This.
    STEVE
    Jun 30 2008
    Erie, Pennsylvania
    ^Or weld some reinforcements to the subframe. But the 034 brackets are srsly baller.
    The 034 rear sway bar is the hot ticket. I tell you.
    Veteran Member Three Rings S4NIK8's Avatar
    Jun 09 2009
    RS6 6 speed
    Somewhere Cold
    Like everyone else has said, make sure the suspension/steering is tight and then sway bars
    Jan 24 2014
    United States
    What are these "adjustable upper control arms" all about?
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Correcting camber.
    Veteran Member Three Rings xthealienatorx's Avatar
    Mar 01 2013
    10 Avant, 03 Superduty 6.0 zf6, 13 Grand Cherokee Overland Hemi
    Louisville, Kentucky
    Quote Originally Posted by S4NIK8 View Post
    I'd love tighter steering, I currently have like 1-2 inch of play in my steering annoying as hell, especially when trying to drive smooth so my girlfriend doesn't yell at me for going around corners "too fast." Anybody know what causes this and how I can fix it? I read somewhere about it being the U-joint.
    Oct 30 2009
    Miami, FL
    Quote Originally Posted by xthealienatorx View Post
    If it's not the tie rods it's probably the steering rack. There is a slack adjustment on the rack that could help, I've never done it but it's been documented here.
    2018 S5 Coupe - stock for now
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    Is it actual slack in the steering wheel or do you turn does it bind before finally turning properly? If it's slack, the above advice will help. Regardless you should lift you car and take a bar to play with your control arms and other suspension components. Check for slack, worn out bushings, etc. All this will contribute to poor handling and feedback.
    MontrealAudiClub
    Jan 24 2014
    United States
    I thought you could only adjust the slack on a FrontTrash car?
    May 18 2010
    ^Nope, all the racks have a slack adjustment. Bentley manual says to have someone turn the wheel back and forth 30 degrees while someone else listens for clunking at the rack. If there is noise heard, tighten up the adjustment without making the rack so stiff that it doesn't return to center while driving.
    01 S4 2.7T: Stock
