Results 1 to 7 of 7
    Active Member One Ring b6mattk's Avatar
    Dec 18 2013
    Vernal utah
    air ride input needed please.
    I put an airlift v2 kit on my 337, but bag setups seem so different on the b6 platform and I really cant decide what set up I want to go with. If you have air ride would you please tell me whats the ups and downs of youre kit!
    B6 a4 1.8t six speed
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    I'd like to hear from people with experience in bags as well. Also would be interested to see their opinions, if any, on accuair - http://www.accuair.com/late-model
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Posting so I can find this later. I'm interested in the responses.
    2008 B7 2.0T Quattro 6MT
    Sold:
    2013 VW CC R-Line
    2005 B6 1.8T Quattro 6MT
    RIP:
    2002 B6 1.8T - April 2019
    2004 B6 3.0 - August 2018
    Dec 18 2013
    Vernal utah
    Quote Originally Posted by A4 Quattro View Post
    im so close just to ordering another airlift v2 kit but maybe not.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    You can start by reading here:
    http://www.audizine.com/forum/forumd...um-by-Air-Lift
    There's a few B6s both sedan and avant and a bunch of B7s on air. B6 and B7 uses the same suspension set-up.
    -Doug
    Veteran Member Three Rings Sam091990's Avatar
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    I'm currently on the Airlift Autopilot V2 setup and I love it, wouldn't choose a different setup but if I were to change anything it would be to upgrade to the Accuair VU4 manifold (nicer, supposedly a lot better & reliable, ability to do hard line setups.) I've dealt with cars using the Switchspeed Analog, Autopilot V2, and E-Level setups and in my opinion I prefer the Autopilot V2.
    Switchspeed Analog - Why waste your money? Get Autopilot V2 or E-Level.
    Autopilot V2 - Simple controller with a ton of options on it. 8 presets are extremely nice and at first I didn't think I'd need more than 2 but I was wrong. Can be set to automatically rise upon start up to your first preset. Ability to maintain your preset within 3 psi or something like that although it is a bit slow. Tank pressure and bag pressure displayed on the controller. Illumination can be changed to desired color to match your interior lighting, compressor run time, compressor maintenance, and a lot more features.
    E-Level - Extremely easy to use controller and can be figured out by anyone (unlike the Autopilot V2 which can be confusing). Only three presets but if you don't need any more than that you should be fine. Sensors can be a PITA to mount and calibrate (they aren't cheap either.) Easily adjust front and rear height with the press of a button (up or down arrow) unlike the Autopilot V2 system which has to be done manually for each corner unless you have a preset. Adjusts height to maintain preset extremely fast.
    Bottom line is if you want the ride height to be adjusted to maintain the preset more precisely or the ability to use your iPhone/iPad then get the E-Level setup otherwise save your money.
    || Instagram @SAMM9690 ||
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    I have the Airlift V2 on my B6 and I'm quite happy with it. The install is fairly straightforward and the it's pretty reasonably priced (compared to it's competitors). Airlift as a company is awesome and really stand behind their product. My install thread is somewhere here on the B6 forum if you do a bit of searching.
    I sourced my kit from Open Road Tuning in PA and they took very good care of me.
    I also considered going with Accuair E-Level, however, I could not justify the extra expense and install hassle when the V2 presets work great (once you get them set up).
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
