Ordered a new axle and hardware a few weeks ago and finally got around to installing (or attempting to install) it with a mechanic buddy of mine this weekend. Axle came out no problem, but the new hardware was not the correct size to attach it back to the transmission. Looks like I ordered the flange bolts for an auto trans instead of manual. However, we tried using hte OEM hardware to attach the new axle, but those bolts wouldn't fit into the new axle. Am I doing something wrong on the install? Shouldn't the OEM bolts fit properly? Could they have sent me the wrong axle? I'll reach out to ECS as well, but just wanted to get AZ's opinion as there is a good possibility I was just doing something wrong
Axle I ordered:
http://www.ecstuning.com/ES248993/ - this is the part number for a manual trans, so it should be the correct one.
new hardware:
http://www.ecstuning.com/ES8637/ - looks like these are for auto, not manual. if i want new hardware I'd need these:
http://www.ecstuning.com/Audi-C5_A6-...xles/ES469134/ (these look like my OEM ones)
Pic of the OEM bolts (longer ones) compared to the aftermarket ones I ordered - I def messed up with this:
Pic of trying to fit the OEM bolt into the new axle. Shouldn't this fit?
Thanks for any ideas or help guys. I can easily just order the manual trans bolts, but I want to make sure that I have the right axle if the OEM bolts don't fit.
