Results 1 to 15 of 15
    Oct 27 2013
    United Arab Emirates
    3.0T supercharger ticking
    Hi guys,
    I'm about to buy my first Audi, an A7 S line 3.0T with all the bells and whistles and I hope you can help me with a question or two.
    I went to a car dealer and he had a 2012 A7 thats still under warranty till October this year. When i turned on the car there were two things that caught my attention.
    1) the trunk would not open from the remote or the trunk release button above the license plate but it opened just fine from the button located on the door. The salesman told me wasn't honestly sure, could be an MMI setting and i could get it looked at as its under warrenty.
    2) This is what i'm really worried about, after starting the engine I noticed it produced a subtle ticking sound from the engine. Salesman told me its the supercharger and i shouldn't worry as thats how it sounds.
    What do you guys think? also are the soft close doors as sensitive and prone to fault like the ones on BMW's?
    Thank for any help
    May 24 2013
    Lakeland, Florida
    Right abt supercharger sound. But don't get it, if there is obvious problems with it. Stay away!! Rule #1 Don't bring trouble upon yourself!
    Veteran Member Three Rings S4Phantom's Avatar
    Jun 10 2012
    Can't answer about the supercharger but does the car have the "valet" setting like the B8 S4? I had the same problem with the trunk not working on the remote or with the release above the license plate but working from the button inside. I had accidentally hit the "valet mode" button located in the glove compartment which disables the remote and license plate button operation of the trunk.
    2011 Phantom Black S4 Prestige Titanium Pkg., Sport Diff., Alu Kreuz, Milltek Non-resonated exhaust with oval tips, AWE Carbon Fiber intake, Stage 1 GIAC, Black powder coated Titanium Pkg wheels
    Veteran Member Four Rings kiku's Avatar
    Jul 11 2013
    2001 Audi S4
    Pittsburgh, PA
    There should be no discerning sound from the supercharger when car is idling. I had an a7 and you couldn't tell the difference.
    2008 997.1 GT3
    2015 Allroad
    2014 Ram 3500 Dually (the double wide)
    2014 Phantom Black RS7 w/ APR Stage 1 Tune (sold - farewall fast rs)
    2001 B5 S4 (the track slut)
    2013 Q7 S-Line (sold)
    May 04 2010
    2013 Audi S6, 2014 Audi Q5 TDI, 2015 GSW TDI 6-spd
    Duluth GA
    It could be the fuel injectors making the ticking noise. Every Audi I've owned (four) has made this sound. Have a listen to another one to see if it has a similar sound.
    Robert Cheng
    2014 Q5 TDI, Phantom Black, S-Line, B&O, Nav, Side Assist
    2013 S6, Estoril Blue, B&O, LED, cold weather, comfort seats, rear shade, BBS CH-R 20x9 ET25, Stasis 25.4mm RSB, Alu-Kreuz
    2010 S4, 6-spd, Meteor Gray, Prestige, Sport Diff, Strat shifter, H&R Rear Sway -- SOLD
    2000 S4, 6-spd, AWE stg3, lots of other stuff -- SOLD
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by maxhawk View Post
    Its not the fuel injectors, they really dont make any noise at all. The ticking you hear on German engines is typically known as "valve tick". These are the hydraulic lifters and they can make a louder tick if the oil gets a little low. Adding half a quart usually helps make it go away.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    May 04 2010
    Duluth GA
    For me, the jury is out on this. When I heard ticking for the first time on my B5S4, I was certain it was the valves. I don't recall who told me or convinced me of it, but I was told that it was the injectors making this noise. An internet search will turn up lots of discussion about ticking sounds, and when the ticking is deemed "normal", folks always say it's the fuel injectors.
    All four Audis I've owned have made this noise, regardless of age or oil level, so I'm inclined to believe what I'm hearing are the fuel injectors. I suppose a good test would be to open the oil fill cap to see if the noise gets appreciably louder. If it does, then it may very well be the valves.
    Robert Cheng
    Mar 20 2004
    Lawrenceville, NJ
    I get what youre saying but theres no moving parts in a fuel injector. It goes "spray" lol. If you are hearing ticks from a fuel injector, you have way bigger problems...
    20 BMW R1250RS
    Veteran Member Three Rings Omnipotent's Avatar
    Jan 04 2011
    Windermere, FL.
    Direct Injection/*High pressure* Fuel Injectors are most likely the ticking you are hearing.
    2013 A7 - Stage 2 - Gone
    2018 S7 - Tornado Grey/Arras red - ordered 7/20/17
    Senior Member Three Rings forza1976's Avatar
    May 16 2011
    2015 M4
    Denver CO
    Quote Originally Posted by a u d i a5 View Post
    This. My b8 s4 and my 335 all made this noise and my wife's 135.
    Veteran Member Three Rings $lick's Avatar
    Nov 06 2009
    2013 Audi S6 Lexus IS300 Turbo
    Chii
    Quote Originally Posted by forza1976 View Post
    my b7 a4 made the same noise... it almost sounded like a diesel at idle. from my understanding, direct injection is responsible for this noise at idle
    -Mike
    2013 S6
    APR Tuned / Lowered / 20x10 Rohana RF2 / Custom Dual K&N Intake
    2003 Lexus IS300T
    2008 A4 2.0t Quattro Avant APR Stage 2+ $old
    Instagram: TwinTurbo_Mike
    Established Member Two Rings mwar99's Avatar
    Oct 06 2012
    Deposit on 2014 911 GT3
    Northern NJ
    Was the car running when you tried to open the trunk? I haven't checked the settings on my car, but when it's running it will only open from the button in the door. My valet button is not on.
    2013 S6 - Estoril Blue
    2015 911 GT3 - Delivered!!!
    Feb 14 2014
    13 S6, 13 Q5, 72 Chevelle
    Oklahoma City
    Its the GDI injectors, not the SC. The sale person just does not know
    And injectors certainly do have moving parts. The pintle opens and closes for every pulse
    Jan 18 2010
    Los Angeles, CA
    any cars with direct injection with have a slight ticking noise while at idle. my Porsche makes the same noise as the audi.
    Sep 22 2013
    Norway
    Quote Originally Posted by MLee View Post
    same sh..., new wrapping :-)
