Results 1 to 14 of 14
    Feb 24 2014
    Rockland county ny
    Please Please help!! No speedometer no tachometer and other electrical
    Please help i have a b6 s4 i was driving one day and my abs and ebrake light came on flashing so i checked the wheel speed sensor and it was unplugged i plugged it in an disconnected the battery then reconnected it now i have no speedometer no tachometer no backround lights on cluster or anywhere in the car and also the mileage not recording and it says push clutch to start in german even while driving anyone have any ideas or have had this problem
    Feb 24 2014
    Rockland county ny
    bump
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by 1sicb6s4 View Post
    Pull the cluster and try disconnecting/reconnecting the connectors.
    Also scan the car with VAGCOM (assuming CAN connects to the instrument cluster)....
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Feb 24 2014
    Rockland county ny
    Ill have to give that a try thanks! Its also weird none of my windows will work either
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Have you looked at the fuses?
    Old Geezer, formerly known as Stud Muffin
    Feb 24 2014
    Rockland county ny
    I checked all the fuses in the fuse box and ecu box and tested them all no luck
    Nov 03 2010
    Cupertino, CA
    Sounds like CAN is down...
    Feb 24 2014
    Rockland county ny
    How do you fix CAN
    Feb 24 2014
    Rockland county ny
    Do you need VAGCOM to fix it
    Sep 26 2012
    San Diego/Bay Area CA
    The same thing is happening to my s4 right now (flashing brake light/abs driving different). You said you checked your wheel speed sensor? Does that normally fix the problem or should I use this as an example to not do this?
    Nov 03 2010
    Cupertino, CA
    How do you fix CAN
    Canbus is a communications network within the car. Most data in the car is communicated over CAN, and most modules will not work if they cannot talk to the rest of the car. If there is a short in the CAN system of the car or if there is the wrong termination at one module, it could cause the entire system to go down. You should have a shop diagnose the Canbus system to identify where the problem is originating.
    Feb 24 2014
    Rockland county ny
    I checked the wheel speed sensor and it was disconnected I reconnected it and reset the battery and it seemed to cause me all these problems i can't figure it out
    Feb 24 2014
    Rockland county ny
    I think that gonna be my next step to bring it to a shop can't understand why plugging in the sensor and resetting the battery caused all these problems maybe something shorted out possibly I appreciate all the help
    Feb 24 2014
    Rockland county ny
    Do you know if the 04 s4 uses CAN
