Thread: B5 clutch 2.8
    Jan 26 2014
    Pittsfield Mass
    B5 clutch 2.8
    The clutch on my B5 2.8 is engaging very high(pedal Height) but it feels
    like it is a long way from giving out. Is this normal for a worn out clutch or
    is something else possibly wrong...slave cylinder, adjustment or ??? Also, how much
    should it cost to have the clutch replaced?? I am also considering just replacing the clutch
    myself...anyone done this service on their A4, and have advice on this job?
    Regards
    Guil
    Veteran Member Three Rings Halfrican's Avatar
    Oct 25 2012
    United States
    Is there any noticeable slipping of the clutch or just a high engagement point?
    Edit: How many miles are on the clutch? A high(er) engagement point does not always mean your clutch is bad.
    Veteran Member Four Rings bhusted's Avatar
    Sep 11 2011
    B5 A4 4.2L V8
    Kirkland, WA
    I wouldn't replace it unless it starts slipping. The engagement point on these cars is high. That's just the way it is. There is no adjustment that I know of.
    | B5 4.2L V8 Quattro | Tein S-Tech | O.Z. Ultraleggera 18x8 | Stabila Course 22mm rear swaybar | Agency Power WRX swaybar links | S4 front brakes | A8 rear brakes | FX-R HID projector retrofit | Fog projector retrofit | RS4 Grill |Aero wipers |
    Veteran Member Three Rings DeltaAlpha9's Avatar
    Jan 03 2012
    '92 Acura Integra GS, '92 Acura Integra GS-R
    Edmonton Alberta, Canada
    B5's have a notouriously high engagement point. That alone doesn't mean your clutch is hooped.
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Very normal for the OEM stock clutch since it doesn't take much movement of the pedal/slave to take all of the pressure off the disk.
