Results 1 to 15 of 15
    Established Member Two Rings S4sha's Avatar
    Aug 30 2012
    2001 S2000
    United States
    why is there chocolate mousse in my engine?
    Ok i know its just a cold frothy accumulation of engine oil vapor... but it was a bit of a surprise when i checked my oil today.
    My drive home from work is only about 5 mins so i wasnt nearly at temp, so i guess when it heats back up it 'dissolves' back into a more oily medium?
    ...right?
    2009 B8 A5 (Dawn) Stasis exhaust (totaled)
    2004 B6 S4 (Sash4) AWE exhaust (sold)
    2007 B7 S4 (Stell4) Dolhpin Gray - Replica R8 Wheels - Fast Inentions downpipes, fullback exhaust, 14" resonators
    2001 Ap1 S2000 (Ruby) - CE28 Volk Wheels - Buddy Club Coilovers
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Today it took me at least 15 minutes for my oil to get to 150* F. (The minimum I consider for hooning). All interstate. I-64/I-71 East from STL.
    Old Geezer, formerly known as Stud Muffin
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Are you saying it was foaming? I'm not sure I follow.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Nov 21 2012
    MK3 GTI VR6 Drivers Edition
    Omaha, NE
    Pics?
    Instagram: @tman52
    Established Member Two Rings useridnotvalid's Avatar
    Jan 28 2013
    Baltimore Md
    Is just condensation that builds when the motor warms and cools in cold weather. It's normally cakes up on all non oil surfaces like the dip stick above the oil line. Under the oil cap and to the bottom side of the valve cover. There's really nothing you can do about it till it warms up. If your super worried you can change the oil but until it get warm outside it Will keep coming back
    Sent from my Samsung Galaxy Note 3
    Aug 30 2012
    2001 S2000
    United States
    Quote Originally Posted by dparm View Post
    no just a bit caked on near the oil cap - exactly what USERIDNOTVALID described
    Aug 30 2012
    2001 S2000
    United States
    Quote Originally Posted by useridnotvalid View Post
    Bingo - not worried at all - just curious if anyone else had come across this
    initial reaction was more like 'wtf is that!??!' then i thought about it and just needed to hear exactly what you just described for a sanity check
    Apr 24 2009
    Frisco, TX
    I would need to some a picture of it. Frothing is not normal. If you are seeing the oil getting milky or changing consistency, that is not normal either.
    Senior Member Three Rings staubach333's Avatar
    Feb 21 2006
    If you were to get the engine highway speed hot for an extended period of time (half hour or so), all that would be completely gone.
    Past---1998.5 A4 2.8Q---18" Privat Netz Wheels---H&R Sports/Bilsteins---DEPO ECE Headlights w/ DDM 55W HIDs---
    Present---2005 S4---18" Alzor Style 050 Wheels---XS Power Catless Downpipes---AWE Track Edition Exhaust (x-pipe, non-resonated)
    AKA: Stub
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    I'm confused. Is just a little normal if it's a short trip or is Dparm right??
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Feb 21 2006
    Quote Originally Posted by jmcS4 View Post
    Normal for a short trip. Engine doesn't get hot enough to evaporate the condensation. Chances are it's just that. Though there could be other problems which could cause a similar froth (coolant in the oil), though that is highly unlikely.
    AKA: Stub
    Apr 24 2009
    Frisco, TX
    Frothing/foaming is different than what happens when coolant gets in the oil. Coolant contamination will cause the oil to get milky and sludge up.
    Frothing/foaming means you are getting tons of bubbles forming, sort of like a bubble bath. That is VERY bad and means the oil could be way overfilled, incorrect lubricant (i.e. they put ATF in the crankcase), depletion of anti-foaming additives, etc. It's hard to troubleshoot but is an easy way to spell a quick death for the motor.
    Veteran Member Three Rings blackedoutt's Avatar
    Sep 16 2007
    B7 S4, MK1 TT, Tacoma
    Southern Indiana
    Small amounts of water condensation within an engine is completely normal. Water can get into the engine through humidity in the air, or EGR (especially cooled EGR systems). Under normal operating conditions the oil will get warm enough to evaporate the water out, which is why overcooling your oil or engine is just as bad as overheating it. I'm not sure about our engines but there are some out there that even use an oil thermostat. Water condensation in oil causes a milky almost mayonaise emulsion to form in certains areas of the engine mentioned above such as dipstick tube, oil fill cap, high/colder crevises of the valve covers etc. Short trips with incomplete oil warm ups can cause it, but a long heat soaking trip can reverse it. It's not really a big deal unless it is more than just water - See Dparms concerns.
    YEAH BUDDY!
    Apr 24 2009
    Frisco, TX
    Correct. Condensation forms in the crankcase through the normal heating/cooling cycles. It's why I suggest people get their car out on the highway periodically so there is sufficient time and temperature to burn off the moisture. Water will thin out the oil.
    Sep 03 2009
    San Antonio, TX
    OP has Chocolate "Mousse" or "Moose" in his engine?!
    MY BUILD
