Hi All,
I am an old member here (formerly MMarkTFSI) but I haven't logged in a while and my account no longer seems to work.
I am having a serious issue with my key stuck in the ignition and I am not able to remove it. I literally cannot leave it anywhere except for my garage because someone could just get in and drive it away.
It's a 2007 Audi A4 (B7) Auto
Here are the symptoms:
- Key will not pass counter clock wise past position 1
- I can turn the car on and drive and all of the gears work
- I can turn the car off, but I cannot take the key out since it wont past position 1
- The Steering Wheel is not locked
- There are no issues with my parking breaks
- There is not a key release button that I can find
- The Gear Shifter button works through all gears, but ONLY pops out when it is in N, D, S, and not in R or P. I suspect this is the reason it is not allowing me to remove my key.
- This is the first time this has happened.
I have tried the following:
- Tapping the gear shifter to get the button to pop out
- Going through all of the gears (about a hundred times) to see if it'll pop the button
- Turn the car on/off (about a hundred and one times)
- Reset the car (unplugged battery)
I've combed through all of the forums and none of them are for B7's. I don't believe that there is anything stuck because the only thing not engaging is the Gear Selector Button.
Any suggestions or resolutions will be greatly appreciated. THANK YOU
