Thread: P2181 Code
    Active Member Two Rings frozone's Avatar
    May 11 2011
    Indiana
    P2181 Code
    Anyone have any experience with this before? I've noticed over the past week my engine temp gauge has gone from 1/3 of the way up, to operating temps, to yesterday being on Cold after even driving an hour on the highway... Then on the way home, the check engine light came on and that's what the scanner is saying. I figured it might be a stuck thermostat, but also kind of pointed to a ECT sensor. Wanted to see if anyone else has experienced this and what their problem was. I'll be starting with replacing the ECT sensor first...
    Senior Member Three Rings va-terps4's Avatar
    Feb 11 2007
    NoVA
    Year and engine spec would help... that code is not unique to the Q7.
    2016 SQ5 Prestige - Glacier White/Black Milano/Carbon Atlas
    2013 Q7 S-Line ... 2008 S6 Sedan ... 2007 S4 Avant ... 2002 allroad
    May 11 2011
    Indiana
    Good call - 2008 4.2 V8
    May 11 2011
    Indiana
    So I just swapped out the ECT Sensor, the gauge is working now, but after a 10 minute warm up and 5 minute drive, the best I could achieve on the temp gauge was 1/4 of the way up... That still doesn't seem right. Anyone else's gauge read that cold while driving around?
    **On a happy note - I just installed the Ziza LED lights from ECS Tuning for my license plate lights... Sharp!
    Feb 11 2007
    NoVA
    I assume you've looked here:
    http://wiki.ross-tech.com/wiki/index...3/P2181/008577
    If you can't get it up to temperature with a reasonable amount of driving, I'd say the thermostat might be stuck open.
