Results 1 to 25 of 25
    Established Member Two Rings DMILLA33's Avatar
    Mar 31 2013
    Wisconsin
    Trying to track this misfire...
    Alright so I bought my xplus Giac tuned S4 about a year ago and every once in a while it would misfire at high rpm. I replaced the plugs with Denso iridium's and it seemed fine but would still occasionally misfire. About two months ago I was trying to figure out how to trace this misfire and I said fuck it Ill wait until it throws a code. Literally ten minutes after it threw the codes for Random/multiple misfire and cylinder 4 misfire. The next morning I swapped the coil pack from 4 to 5 and it was fine for about a month and now it started doing it again only it will not throw the code! Is there anything else I can do or just wait for it to throw the code again!? I want to do the 2.0 coil conversion but I just dropped to much money on coilovers and wheels...... Maybe this summer. So for now I need to figure this out...
    Nov 19 2013
    Seattle, Wa
    Good luck man, I've been trying to figure out my misfire on cylinder 4-5-6 and no luck so I gave up. I tried pretty much everything
    Mar 31 2013
    Wisconsin
    Yeah man its such a bummer! All my buddies wanna race but I have to tell them no cause I'm trying to track this misfire... I luckily haven't really dropped money on it besides plugs but if I don't throw a code within the next few months and it doesn't go away I'll be purchasing the 2.0 conversion
    Active Member Two Rings OneBadb5's Avatar
    May 14 2013
    2001 Audi S4 6spd (Santorin blue) SOLD
    Bronx, New York
    I have a P0300 code for random multiple cylinder misfire but I'm not getting a specific cylinder. I hear our ICMs are a common failure. Maybe you can start there..
    Apr 16 2013
    Colorado
    Quote Originally Posted by DMILLA33 View Post
    I was able to do this diy conversion http://audisrs.com/ftopic43267-0-asc-105.php for under $225, might be worth checking out.
    Mar 31 2013
    Wisconsin
    Quote Originally Posted by Speed4Avant View Post
    Did you use plug n play or did you have to wire it up yourself? Wiring up stuff just makes me nervous.. I'd rather spend the extra money for 034's plug n play! But like I said, no cash for anything like that as of now! looks like I have to wait on downpipes!
    Veteran Member Three Rings spyder101's Avatar
    Jan 25 2009
    some where in the U.S.
    If you have access to VAGCOM or a scantool, you can observe MVB 14, 15 and 16 in the Engine control module. With this, you can see if the misfire is stationary on one cylinder or moving around. Yes, it is common for the Output stages to fail on these cars too.
    Apr 16 2013
    Colorado
    I bought these plugs http://www.ebay.com/itm/151113693949...84.m1497.l2649 just have to splice 4 wires on each connector, no soldering needed. Bought icm deletes prewired for $27 shipped.
    Mar 31 2013
    Wisconsin
    Does that require cutting any of the stock harness? or does it plug into the stock
    Senior Member Three Rings Breppinq's Avatar
    Apr 05 2012
    VW ATLAS, VW JETTA GLI MK4
    Long island, NY
    I get a random misfire code like once a month lol even after my fsi conversion. Never affects anything drives normal idles fine I just gave up on it.
    Mar 31 2013
    Wisconsin
    Quote Originally Posted by Breppinq View Post
    Lol! thats shitty man... My car idles fine and everything until high rpm and its only occasionally. Sometimes it will pull extremely smooth and then sometimes it will just start misfiring hard!
    Apr 16 2013
    Colorado
    you cut off the old connectors at coil pack
    Feb 21 2011
    WA
    All of you need to check lifters, lobes and the harness for shorts.
    If pressure test and coil/ICM swapping doesn't solve the issue then it is time for a leakdown and harness inspection. I'd do it in that order because I hate looking for shorts without the right equipment.
    ICM Delete / Coil conversion is a great mod for healthy motors to replace ignition components that are prone to fail. It is not a fix for difficult to diagnose misfires.
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    FSI coils or FAIL!
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Veteran Member Three Rings VAGlover's Avatar
    Sep 23 2013
    b6 a4 track rat
    boston
    Just get new coils already. Check if they have oil/burnt oil on them as well as plugs
    Sent from my iPhone while steering, changing gears, smoking a cigarette and drinking a coffee. Maybe eating a breakfast sandwich too.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    honestly could be 02/egt sensor related. the whole ignition/air sensor system on this car is WAY too complicated for its own good. and parts fail intermittently, and the computer doesn't know what's what.
    if it's a minor issue, live with it. if it's bugging you, find a buddy and swap parts with him.
    Senior Member Three Rings A4-B6's Avatar
    Nov 09 2009
    2011 S5 Prestige Briliant Blk/Pearl
    N.CALI
    What James said. My car did this for a while and didn't stop until I swapped out my EGT's. I haven't had the problem since. Coil packs, plugs and ICM didn't help.
    Good luck!
    SOLD
    Nogaro 2001.5 S4
    JHM built
    12.1 @116 MPH
    2011 S5 Prestige
    https://imgur.com/a/YKQww#0
    Fast Intentions exhaust, Euro tail lights, RS5 front grill w/fogs, JHM 382mm BBK, Lightweight disc x4, JHM tune, VOLK G2's, JHM Stage3 clutch, JHM Supercharger kit, JHM HFC's.
    Established Member Two Rings Attrick07's Avatar
    May 30 2013
    Massachusetts
    6 new coil packs helped my misfire issue, car also didn't throw a code probably because there were multiple cylinders misfiring, some of my coils were even cracked
    Mar 31 2013
    Wisconsin
    Quote Originally Posted by Attrick07 View Post
    Thanks for the input guys! Yesterday I ripped on her a little bit and zero misses so I'll just wait until I get a consistent misfire or until it decides to throw the code again before I start replacing expensive parts....
    Mar 31 2013
    Wisconsin
    It is hilarious that whenever I try to look into this misfire my car decides to throw a code when I'm about to say fuck it again! Originally it was throwing random/multiple misfire and cyl 4. I swapped the coilpack with cyl 5 and now two months later I'm finally throwing a code for cylinder 5! Going to pick up a coilpack after class!
    Nov 21 2012
    Ohio
    I tracked an idle misfire for what seems like forever. Then my fuel pump went out, replaced it and misfires went away....
    May 30 2013
    Massachusetts
    Replace them all, then you'll never have to worry about coilpacks again
    http://www.ecstuning.com/Audi-B5_S4-...nition/ES8037/
    Senior Member Three Rings mooseclap05's Avatar
    Sep 16 2012
    Supercharged Tundra, B7 RS4
    Flagstaff, AZ
    Quote Originally Posted by OHS4 View Post
    if its a fuel pump issue.. are there symptoms to see on vcds that it in fact are causing issues ? am i right in thinking she'll go lean or rich depending on how the pump takes a dump?
    Nov 21 2012
    Ohio
    I don't believe there is anyway to diagnose low fuel pressure in vcds.
    Mar 31 2013
    Wisconsin
    I'm piecing together a 2.0 coil conversion within the next two months so when it gets nicer out I'll be ready! But I got a coilpack from a buddy for twenty dollars brand new and she pulls awesome!
