Hello all!
I bought a used Audi this week and I have a little problem that has got me scratching my head. It all started when I checked the oil. I pulled the dipstick: nothing! I also noticed that the dipstick funnel was broken (a common issue I learned) so I replaced the funnel with a brand new one and added oil until it was at the full mark (about 1.5 liters). 10 seconds after I started driving away, I looked in the mirror. There was a cloud of white smoke with a blueish tint so thick I could not tell if there was a car behind me. I pulled in a parking lot and let it idle while I checked to see if the oil pressure light would come on while I revved the engine. It smoked for about 5 minutes until I drove away where it smoked some more until it stopped smoking completely. Once I was home, the rear bumper was coated in engine oil and the tail pipes were dripping oil. I looked at the oil level again: barely any oil on the tip of the dipstick.
I had to travel this week and I did no less than 300 km without a trace of smoke until the low oil level light came on. I added 1 liter of oil and once again, the smoke cloud appeared but not as long as before.
I had some time to work on it this weekend and the first thing I did was remove the charge pipe going to the intake manifold. The throttle body and pipe were dripping in oil. This led me to believe that oil is entering the manifold and going through the engine. A little more searching and the PCV system was the next place I looked. What I thought was happening was that a check valve was blocked and that the engine crank case was under vacuum all the time and was pulling oil into the manifold.
2 hoses were also cut but I decided to remove the entire system for my testing. The rubber ''Y'' that is connected to the valve cover is completely removed and venting to atmosphere. I then removed the plastic pipe that is held in place by a clip and connected to the engine block. The plastic piece is also broken and will need to be replaced. The block and cylinder head are now venting to atmosphere. I added oil until the level on the dipstick was at the full mark and sure enough, the infamous white cloud was back. When it stopped smoking, barely a drop of oil on the dipstick.
Somehow, a lot of oil is enterring either the intake manifold or exhaust system and I have no idea how.
Here is what I think it is not:
-engine coolant: this is obviously oil. I know coolant burns white and oil burns blue but if oil is dumped directly into the exhaust, it does not burn and smokes white. The smoke smeels like burned oil too.
-head gasket: the car idles perfectly at 900 rpm. It would not if the head gasket was bad.
-turbo seals: the turbo was replaced by a brand new OEM turbo 6 months ago. Also, if the seals were bad, shouldn't it smoke all the time?
-pistons and rings: why would it only smoke when the oil level is at the high mark?
-valve seals: it should smoke all the time and the amount of oil that goes through bad valve seals is not enough to make a cloud of smoke like it does.
-SAI system: the hose that goes to the pump and is connected to the valve cover is disconnected so no oil can go through there.
Could this have something to do with the EGR valve? I know there is a vacuum line that goes from the valve and is connected to the intake manifold. Could it be sucking oil through there or could oil be dumped right in the exhaust when the level is high?
Somehow the car smokes but only when the oil level is at the maximum.
Any ideas are welcome.
