Results 1 to 11 of 11
    Veteran Member Four Rings mattchat's Avatar
    Feb 12 2012
    2014 Honda Odyssey - Touring Elite
    Calgary
    auto adjust seats not working
    So was cleaning the car the other day, had my seats all they way back to work on the mats and make it easier to remove them and when I went to push number 1 on the door to move the seat back to my position, nothing happens (and no, the OFF button is not on), so I start up the car, get in and hit 1 again, nothing. I think the memory setting was erased so I hold set down for a few seconds after adjusting my seat so that I can add it to memory again and nothing, no beep, like usual. Anyone else had this issue?
    2013 S4 - Monsoon Grey - 6spd - ADS - Carbon Atlas - Magma/Black Int.
    Mods: RS5 Red GT front and rear brakes, VMR v710 19x8.5 w/ Mich PSS (S), Audi Ti 19x8.5 w/ Pirelli Sottozero (W)
    AWE + RES DP exhaust, AWE Carbon S-FLO, P3, Eurocode Meisterwerk ASTS, eCode headlights w/ ZKW clear lense swap + Philips Xtreme
    KW HAS, Eurocode USS, Alu Kreuz, DEVAL C/F rear Valence, Black Op Front Grill w/ Chrome Combo, Folding Mirrors
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    Check the fuse?
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Is this a B8.5 only feature?
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Senior Member Three Rings ob_1jr's Avatar
    May 05 2012
    Clinton, UT
    On mine I have to hold the button for the memory function to work
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by Usa View Post
    No, B8s had it on the Prestige trim. My 2010 Prem+ did not have memory seats. 2014 P+ does.
    Established Member Two Rings Santana's S5's Avatar
    Jun 18 2012
    2011 Audi Q7 TDI (Sold), 2009 Audi S4 Cabriolet (Sold), Audi A6 4.2L (Sold), Audi S5 4.2L (Sold)
    West Palm Beach, FL
    I am having the same problem and didn't see anything in the fuse box related to seats.
    Audi S5 4.2
    Mod's: Sprint Booster, APR Stage I, APR Intake, AWE Non-Res Downpipes, AWE Touring Exhaust, KW V3 Suspension w/ Iphone Interface, RS5 Carbon Fiber Interior, RS5 Flat Bottom Steering Wheel, Front & Rear Brembo BBK, RS5 Grill, Adaptive Ecodes, LED Tails, S5 Shifter, Deval Carbon Fiber Lip and Carbon Fiber Rear Valence, Escort Passport 9500ci
    Future Mod's: Supercharger
    Feb 25 2013
    MI
    Can you run a vagcom scan, there should be an ecu for memory seats? Or one of the body control modules. You could also try the second key.
    Jan 01 2009
    04 Black A4 1.8T Q 10 A5 S-line. '12 S4
    So Cal
    sounds like seat motor might have lost there memory when you moved them. run seat motor to max stop. so run it all the way forward, backwards, up, down and till to all max position. mine did that and i ran this and it started working again.
    Feb 12 2012
    Calgary
    Tried second key, can't find a fuse related to seats. I know it's probably not a fuse as I can push one of the buttons while using the seat adjustments and it interrupts it from moving, and the light comes on for the off button when I push it. You have to hold the number button if the door is closed, and just tap it if the door is open. B8 and 8.5 are exactly the same as far as I know. So think I will try the max settings and see if that forces it to work again. Thanks for the suggestions.
    EDIT: Thanks dpeturboa4, that fixed it. Moved seat all the way back, forward, up down, tilt both ways, lumber and when I pushed "set" the light went on....yeah!
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Quote Originally Posted by mattchat View Post
    Sounds like secrete Contra NES code to me.
    Feb 12 2012
    Calgary
    UP UP DOWN DOWN LEFT RIGHT LEFT RIGHT B A SELECT Start, I'll try that next time on the new models coming with Android devices plugged in.......ah, good memories.
    Quote Originally Posted by SwankPeRFection View Post
