Results 1 to 4 of 4
Thread: Oil pan removal
    Mar 05 2012
    11 Q5 2.0T, 18 Q7 3.0T, 89 Foxbody!
    Bucks County, PA
    Oil pan removal
    Is it possible to remove the lower steel oil pan with the motor in the car and without removing the subframe?
    Sent from my XT1080 using Tapatalk
    2012 Q5 and 2018 Q7
    Veteran Member Four Rings 0000 V8's Avatar
    Feb 19 2010
    Porsche Cayenne Turbo, B6 S4, C5 Allroad, B5 A4, Prius C
    Sacramento, CA
    Yes. You do have to move the front coolant line out of the way and also there is a line that goes along the rear if the pan that needs to be unbolted and moved aside. Make sure you use the correct sealant when putting it back on.
    Why do you need to remove it?
    Veteran Member Four Rings gcoy's Avatar
    Apr 06 2009
    2005 B6 S4 6mt Avant & 2001 B5 S4 6mt Avant (Sold) & 2007 VW Passat 3.6 4Mo wagon
    Boise Id
    Why do you need to remove it?[/QUOTE]
    Mar 05 2012
    Bucks County, PA
    I have to get the chunks of timing chain guide out. Already did the chains and after I put it back in the car I want to drop the pan.
    2012 Q5 and 2018 Q7
